JD10888 Posted February 16, 2019 Report Share Posted February 16, 2019 so i have an electrical problem i have a 1985 720 with a sd25 diesel i put a brand new battery in i have to roll start it every time when i turn it off it just clicks the engine wont even turn over the battery it still reading around 12.2volts so theres nothing wrong with the battery im guessing its the starter relay or the starter but im not exactly sure witch one Quote Link to comment
]2eDeYe Posted February 21, 2019 Report Share Posted February 21, 2019 Sounds like either the starter relay or a bad wire connection at the relay or starter. You can pull the starter out and test it on the ground with some jumper cables. Neg to the case of the starter and positive to the main starter lug. Then test the solenoid with the positive on the solenoid lug and a jumper to the solenoid trigger. The starter should spin and push the starter gear out to engage the flywheel. Quote Link to comment
JD10888 Posted September 6, 2020 Author Report Share Posted September 6, 2020 Im not sure why when i posted this it changed my wording its nothing to do with the start motor i replaced that. ever since i replaced the headgasket it cranks but wont start i have cracked the fuel injector nuts there is fuel dribbling out so fuel is getting to all 4 cylinders and there is power getting all 4 glow plugs what could it be Quote Link to comment
wayno Posted September 6, 2020 Report Share Posted September 6, 2020 (edited) OK, does this engine have a inline injection pump or a VE type injection pump? This is an inline injection pump with the injection lines coming out of the top of the injection pump. And this is a VE type pump that the injection lines come out the rear of the pump. It depends on what type of injection pump you have on what may be the issue, when you did the head gasket did you do anything else like replace the spin on fuel filter? Edited September 6, 2020 by wayno Quote Link to comment
datzenmike Posted September 6, 2020 Report Share Posted September 6, 2020 7 hours ago, JD10888 said: Im not sure why when i posted this it changed my wording Quote Link to comment
JD10888 Posted September 7, 2020 Author Report Share Posted September 7, 2020 wayno Datsunahaulic no all i did was remove the lines apparently i might have to do the valve adjustment. I have a VE pump and have not replaced the fuel filter Quote Link to comment
wayno Posted September 7, 2020 Report Share Posted September 7, 2020 OK, on that VE type injection pump there is a wire on top, when the key is turned on it should click, that would be the solenoid opening up allowing fuel to flow, if that wire is not connected or doesn't have 12 volts when the ignition is turned on the engine will never start or run, if it does not click it may also have went bad and is not functioning properly. I do not know how to bypass that part if it is bad as I have never had an issue with it, so I don't know if it can be removed and have the engine run properly or if it will just puke fuel everywhere. Quote Link to comment
