Underhood Fuel Line Grommet
Tedman
As far as I know, these are NLA.  I have rerouted my fuel lines so have no need for this hole anymore. Aside from welding it up, anyone ever found an oval rubber plug that fits?
  • Replies 5
FWIW...The pat # is 24250-89937. Which is odd as the leading "24" indicates that it should be in the electrical group. Possibly this is used elsewhere on the vehicle for a harness pass through. Using vacuum line split down the middle can work, but I have always found it to be a little bit of a bitch kitty myself.
@D52E  Thanks for that Realm link!  Naturally the eBay link from 2010 is dead but I searched eBay motors for "oval rubber plug" and several came up, mostly for '99-'06 Jeep Wrangler. One had dimensions, so I'm gonna go measure the hole...
  • 1 month later...
I have used those Jeep grommets. They don’t fit tight and pop out pretty easy. With a hose running through it wil not stay. But if you want to use something in place of it you can.
I used a round flat soft rubber plug used for sheet metal. Wasn't oval but when you get the right size it will conform. Drill out a small hole for the fuel line and it should work fine.
