ratsun777 Posted February 4, 2019 Report Share Posted February 4, 2019 1974 Datsun 620 l18 Changing my belt and loosened the bolt on the alternator bracket but the alternator won’t move to get it closer to the other pulleys so I can slip the belt on. Any suggestions Quote Link to comment
Crashtd420 Posted February 4, 2019 Report Share Posted February 4, 2019 By the way you said it, it sounds like you only loosened the adjuster bolt. Did you loosen the 2 underneath connected to the bracket that is bolted to the block? Quote Link to comment
ratsun777 Posted February 4, 2019 Author Report Share Posted February 4, 2019 No I didn’t. Do I also need to loosen those to be able to move the alternator to give me slack to put the belt on? Quote Link to comment
Crashtd420 Posted February 4, 2019 Report Share Posted February 4, 2019 Yes .... you need to loosen all 3. . I usually tighten the top one first once I tension the belt then tighten the ones underneath.... 1 Quote Link to comment
ratsun777 Posted February 4, 2019 Author Report Share Posted February 4, 2019 Thanks I’ll give it another go once this rain stops Quote Link to comment
Crashtd420 Posted February 4, 2019 Report Share Posted February 4, 2019 1 minute ago, ratsun777 said: Thanks I’ll give it another go once this rain stops Ya crawling under to get those 2 bolts will suck in the rain.... Dont take them all the way out if you dont have to, just crack them loose... Quote Link to comment
ratsun777 Posted February 5, 2019 Author Report Share Posted February 5, 2019 Thank you so much so those other two bolts are right underneath the alternator? Quote Link to comment
datzenmike Posted February 5, 2019 Report Share Posted February 5, 2019 The bolts one front and one back that go in the bottom holes. The alternator swings on them like a door. Once the belt is adjusted, press hard with thumb in middle of belt between pulleys and it should move about a belt width, tighten these two bolts again. I think they are 17mm 1 1 Quote Link to comment
ratsun777 Posted February 5, 2019 Author Report Share Posted February 5, 2019 Thank you so much for the information Quote Link to comment
