Stephen22 Posted January 29, 2019 Report Share Posted January 29, 2019 Hi guys, with my Datsun 510 the guy gave me a diff. Can you please help me identify this diff?? Quote Link to comment
thisismatt Posted January 30, 2019 Report Share Posted January 30, 2019 It's an R160, same as stock. No way to tell what the internals are. You can figure out the ratio by number of turns, and you can check if it's a limited slip (or welded) by turning one output stub and seeing if the other turns the same way (if the other turns backwards than it's open, like stock). Quote Link to comment
Stephen22 Posted January 30, 2019 Author Report Share Posted January 30, 2019 Thanks. My current diff is welded and I really do not enjoy it. So I will replace it with this diff and see how it goes. Quote Link to comment
datzenmike Posted January 30, 2019 Report Share Posted January 30, 2019 Pop the rear cover off. The ratio is stamped on the outward facing edge of the ring gear and non LSD will be obvious. 39:10 is 3.889 and 37:10 is 3.70. LSDs are a two edged sword and welded diffs are scary dangerous. Quote Link to comment
Tedman Posted January 30, 2019 Report Share Posted January 30, 2019 38311 21100 pn cast into top of case indicates a stock 510 R160. What Mike said about id'ing ratio. Quote Link to comment
datzenmike Posted January 30, 2019 Report Share Posted January 30, 2019 Used on 2 and 4 door 510 and 610 sedans through July '73. Quote Link to comment
Stephen22 Posted January 31, 2019 Author Report Share Posted January 31, 2019 Thanks guys. I am going to fit this diff back, the welded diff is terrible. I just hope it lasts. Quote Link to comment
Stephen22 Posted February 6, 2019 Author Report Share Posted February 6, 2019 I removed my diff that was welded. Can anyone tell me what diff this one is? I thought it was the same as the ones in the photos above but its slightly different. Quote Link to comment
datzenmike Posted February 6, 2019 Report Share Posted February 6, 2019 There's bound to be some revisions over the years and Subaru uses the same R-160 in their cars. If the ratio is the same and the carrier fits... just swap it entire. If swapping the internals you really need to have the gear lash set by an experienced tech. You can (but should not) just bolt it in if you want long life out of it.. Quote Link to comment
