vetteguy22 Posted January 28, 2019 Report Share Posted January 28, 2019 I’m picking up a set of 280zx struts to convert it coilovers for my 1972 510 with a VG33 conversion. I have done a lot of research on the different brands but thought I’d ask what others have used and why? thanks, Rob Quote Link to comment
banzai510(hainz) Posted January 30, 2019 Report Share Posted January 30, 2019 (edited) I have a T3 coil over set up annd use a 7inch(mosat are the 8in tall) 180pound spring. I wanted it lower as my spring perch needed to be at stoclcation for my +25mm rims. More orless didnt want the perch to hit the tire. on 280zx your perch mayb to lower as one uses more like a 0 or +12mm offset rim and it wollbefarther away from the strut tube Edited January 30, 2019 by banzai510(hainz) Quote Link to comment
vetteguy22 Posted January 30, 2019 Author Report Share Posted January 30, 2019 It looks like the T3 uses a winch bolt on the lower perch that tightens into the threads of the tube, is that correct? If so I’d be afraid it would lead to thread damage after several adjustments for street to autocross changes. What do you think? Rob Quote Link to comment
Icehouse Posted January 30, 2019 Report Share Posted January 30, 2019 2 hours ago, vetteguy22 said: It looks like the T3 uses a winch bolt on the lower perch that tightens into the threads of the tube, is that correct? If so I’d be afraid it would lead to thread damage after several adjustments for street to autocross changes. What do you think? Rob I just hand tighten the lock nut on the spring perch. If the upper bearing is doing it's job it shouldn't loosen up. Quote Link to comment
vetteguy22 Posted January 30, 2019 Author Report Share Posted January 30, 2019 Ok thanks Quote Link to comment
Draker Posted January 30, 2019 Report Share Posted January 30, 2019 I'm running gc coilovers on uncut 280zx struts. Quote Link to comment
paradime Posted January 30, 2019 Report Share Posted January 30, 2019 T3 sells the component parts to build your own coilovers with the ZX struts, or 510 struts. https://technotoytuning.com/nissan/510/front-weld-coilover-kit-datsun-510 I'm running their equipment on modified ZX struts with 15X7 +22 offset rims and have no contact between tire and upper perch. The winch bolt does not tighten directly into the threads. It contacts a larger surface that keeps the lower perch from moving, and does not damage the threads. Quote Link to comment
vetteguy22 Posted January 31, 2019 Author Report Share Posted January 31, 2019 Thanks for that info paradime. I plan on doing the coil over kit myself. When you say modified ZX struts, are you referring to the coil overs or did you do something else also. Quote Link to comment
paradime Posted January 31, 2019 Report Share Posted January 31, 2019 4 hours ago, vetteguy22 said: Thanks for that info paradime. I plan on doing the coil over kit myself. When you say modified ZX struts, are you referring to the coil overs or did you do something else also. No worries Vett. The struts are shortened and the compression damping is adjustable. Quote Link to comment
rosso Posted March 4, 2019 Report Share Posted March 4, 2019 Ordered my T3 coil over kit Friday - should ship tomorrow. Dave Carroll will cut off the spring perches and weld the collars on for me. Stock 280ZX struts with KYB shocks and 200 lb springs. (softer springs recommended by both T3 and Dave even with the VG33 swap) This may be a little soft, but the KYB shocks apparently can't handle stiffer springs and the KYB are way less expensive than Koni, Bilstein, Tokiko etc and my budget just couldn't stretch that far. Drywall being done in the garage all this next week so the car and parts are all covered and no work being planned. 2 Quote Link to comment
Jesse C. Posted April 19, 2019 Report Share Posted April 19, 2019 I am running 1987 200SX front struts. They push the wheel back out and eliminate the need for spacers on certain 0 offset wheels. And, it gives you more room on the backside for positive wheel offset. My 510 has BRE flares on it. And I am using T3 Sleeves with 350 lb. Eibach springs, as I am also running a VG Quote Link to comment
rosso Posted April 20, 2019 Report Share Posted April 20, 2019 Here are my T3 coilover kits installed on the 280ZX struts. Not shortened. Retaining rings are welded so top of threaded sleeve is just far enough below the top of the strut to allow tightening the top big nut. The spring perch is set temporarily all the way up to keep the spring captured with shock extended all the way. The perch collars have a nylon ball in the set screw hole so that when you tighten the set screw it presses on the nylon ball and that presses against the threaded sleeve This was a very inexpensive way to get a coilover setup on the front. They offer a store credit for struts and this kit fits both the 280ZX and stock 510 struts I won't get to installing them until after I finish the garage into studio remodel and I have some time (May 1 goal). 2 Quote Link to comment
