Charlie69 Posted February 16, 2019 Report Share Posted February 16, 2019 16 hours ago, jcard said: That's what I tried, heat turned it all into a sticky mess I was fortunate to be able to clean up. I wouldn't recommend it. I've since fixed the issue. I was able to get some large heat shrink tubing to go around the rubber connector. Turned on defroster and tubing shrunk to fit connector, problem solved. For now. I have never had a 520 or a 521 heater get hot enough to melt the adhesive on duct tape! LOL Quote Link to comment
wayno Posted February 16, 2019 Report Share Posted February 16, 2019 (edited) I have Charlie, during the summer, I run my heater every time I drive the work truck, doesn't matter if summer or winter, I figured it helped cool the engine as I am using a stock 521 radiator with my LZ23 and i have my foot into the pedal most the time as it takes power to move 6000/7000lbs up grades and to get it moving when it is loaded up. The outer coating of the duct tape disintegrated and what was left was a sticky stringy mess, I am sure it is over a 100 degrees down there on hot summer days in my truck. Edited February 16, 2019 by wayno 2 Quote Link to comment
Charlie69 Posted February 16, 2019 Report Share Posted February 16, 2019 You got me on that one Wayno. I have never run my heater here in Phoenix in the summer. Quote Link to comment
thisismatt Posted February 16, 2019 Report Share Posted February 16, 2019 Bosch 35mm vacuum hose fits the heater box perfect. I didn't have a spare dash duct handy to try that end. 1 Quote Link to comment
