Z22 piston rod needed
720kid
  • Replies 7
This is for a 720 engine? The L20B rod is identical. Both are 145.9mm between crank center line and piston pin center line.
You need to start a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/  ... buying and selling are not allowed in the forums.
just putting this here to help clarify things. Connecting rods
Center to center length, all use the same 21mm diameter piston wristpin.
L18, L28, L26--------------130.2mm
L16, L24---------------------133.0mm
L13----------------------------139.9mm
L20B, Z22S, early Z22E-145.9mm*
Z20S,- ------------------------??**
Late Z22E-------------------149.5m*
Z20E--------------------------152.5m
Z24, KA24-------------------165.0m
