60 series transmission???
K Appley
  • Replies 2
The rear of the 60 series 4 speed does not have room for the fifth gear. Why would it? All it was intended for was the reverse gear and idler. There would be no provision for a 5th gear spline on the mainshaft. If it was even possible.... you would need to swap the main and counter shafts to provide mounting points for the 5th gear and the tail for extra room.
13617.jpg 4 spd. top and 5 spd. below it.
