Justin620datsun Posted January 12, 2019 Report Share Posted January 12, 2019 (edited) I'm curious as to what the resistor looking thing is under my dash. Is it a alternative to something? How do I get rid of it? And what is the solenoid looking piece to the left? Just looking to clean this up and got rid of the mess. Thanks for any info on this. Edited January 12, 2019 by Justin620datsun Quote Link to comment
Crashtd420 Posted January 12, 2019 Report Share Posted January 12, 2019 Are you talking about those round cylinders? The clear one looks like a newer flasher .... and the silver one is an older one.... Ones for the turn and one is the hazards.... Quote Link to comment
Justin620datsun Posted January 12, 2019 Author Report Share Posted January 12, 2019 So maybe the old one stopped working and someone did that? Turn signals and everything work I was just curious why it was there. Quote Link to comment
datzenmike Posted January 12, 2019 Report Share Posted January 12, 2019 That is the turn signal unit. The electronic flasher does not have the tab on the side of it that holds it in place like the silver colored one it replaces. Use some zip ties to hold up out of view and you're good to go. We had a guy here many years ago who tore out all the 'unnecessary wiring'. (we warned him) He then spent the next 8 months pestering everyone to help him figure out how the wipers worked because winter was coming and the rain setting in. Then the heater and turn signals because it was October and too cold for arm signals, then the horn. He's long gone now and I can only assume he is a victim of Darwinism. Quote Link to comment
Justin620datsun Posted January 12, 2019 Author Report Share Posted January 12, 2019 Ok gotcha. Just wanted to know if it was some temporary fix that I was going to have issues with later on. I'll zip tie it out of sight. Another question. I can't seem to find exactly what I'm looking for. My truck doesn't have a tach and I'd like to install one. My truck is a 78 and I was wondering if someone had a link to a how to thread on it. Quote Link to comment
Crashtd420 Posted January 12, 2019 Report Share Posted January 12, 2019 1 hour ago, Justin620datsun said: So maybe the old one stopped working and someone did that? Turn signals and everything work I was just curious why it was there. It looks just like the one I had to buy to replace the old turn signal flasher in my 521.... as long as it works..... It looks like the silver one is unplugged.... so if everything works maybe its replacing that unplugged one... As far as the tach adding one is simple... Usually 3 wires.... Ignition power Ground And signal from negative side of coil.... Mount where you wanna..... Quote Link to comment
datzenmike Posted January 12, 2019 Report Share Posted January 12, 2019 The old style units were driven solely by load so the more lamps, like a trailer, the faster they flashed. If one burned out the speed was much reduced or even stopped. Newer ones are electronic and the pulse rate is fixed, however if one lamp burns out you won't know it. Wrecking yards are full of them and they fit nicely into your pocket. Quote Link to comment
Justin620datsun Posted January 13, 2019 Author Report Share Posted January 13, 2019 Ok good to know. Not many wrecking yards around here have 620 pickups in them. Just wanted to make sure I knew what it was for which that's what I figured its purpose was. Any brand recommendations for tachs? And should I wire it in at the ignition plug or somewhere else? Thanks guys. Quote Link to comment
datzenmike Posted January 13, 2019 Report Share Posted January 13, 2019 The 620 had a tach option and the earlier Darsun 110 or 1200 had the same one. You could try an ad in the classifieds but probably cheaper to get something after market and mount it in the dash on the far left side. Wiring is best done using the tach instructions you buy. The '79 does have the tach option wiring plug tapped up in the harness just above the left hand side of the dash. Some of those wire could be used including the illumination. Quote Link to comment
