CicliDevotion Posted January 12, 2019 Report Share Posted January 12, 2019 My '83 4X4 currently has a slider rear window. It's missing some hardware and one panel is broken...but I have a replacement slider to swap out. I came across this pic of a nearly identical truck, though this one has a solid rear window: I am REALLY liking the cleanliness of the non-slider window. So now I'm thinking about a solid for my truck instead... Before I commit, below is my understanding of some primary pros and cons PROS: Better Ventilation Cooling CONS: Less secure Worse Visibility Noisy What are your feelings? Strong preference for one over the other? Should I swap mine out? Have a solid that you'd like to trade? Quote Link to comment
weldingrod Posted January 12, 2019 Report Share Posted January 12, 2019 I have an old 84 740 (now a parts truck) and the ventilation or security issues never occurred to me. It just seemed to clutter up the clean lines of that part of the cab. 1 Quote Link to comment
bottomwatcher Posted January 12, 2019 Report Share Posted January 12, 2019 I put a slider in mine in 89 so I could put long things in the truck and lock it (with a camper shell). Also allowed communication with the rest of the posse that was forced to ride in back due to removal of the jumper seats for speakers. Those days are long over and the sliding window channels are filled with silicone to stop the constant rattling they aquire, still have the solid glass stored away. It will go back in one day. 1 Quote Link to comment
Madkaw Posted January 12, 2019 Report Share Posted January 12, 2019 The idea of options for ventilation and utility make me want to convert to a slider. You can still purchase them new for reasonable . I’ll just keep my solid glass if I want to go back. I think with the standard cab the slider makes a little more sense because it’s so easy to reach . You could almost grab a drink from your cooler in the bed. 1 Quote Link to comment
CicliDevotion Posted January 12, 2019 Author Report Share Posted January 12, 2019 Very true. But my truck is a hard top convertible...so I can always just ditch the top half of the cab if I need to carry something oversized or have easy bed access! 1 Quote Link to comment
CicliDevotion Posted January 13, 2019 Author Report Share Posted January 13, 2019 Assuming I want to switch to a solid... Its my understanding that I will need to find one from another single cab (a king cab window won’t fit...) Anybody know what years are the same size as an ‘83? 1 Quote Link to comment
Madkaw Posted January 13, 2019 Report Share Posted January 13, 2019 Maybe we can trade !? 1 Quote Link to comment
CicliDevotion Posted January 13, 2019 Author Report Share Posted January 13, 2019 1 hour ago, Madkaw said: Maybe we can trade !? Where are you located? Quote Link to comment
CicliDevotion Posted January 14, 2019 Author Report Share Posted January 14, 2019 Well it turns out that the spare rear slider I have is from a KC and won't fit in my single cab...so I'll have to find a new home for it. Unfortunately, the slider currently installed has a broken pane (the static side, right behind the driver)...which is why I grabbed the spare from the parts truck. Anyone have a good source for a solid rear for a single cab? Bonus points if its in SoCal... 1 Quote Link to comment
CicliDevotion Posted January 19, 2019 Author Report Share Posted January 19, 2019 Can anyone tell me what model years will have back glass that will fit my ‘83 single cab? (I’m looking for a solid rear window.) 1 Quote Link to comment
Charlie69 Posted January 19, 2019 Report Share Posted January 19, 2019 (edited) All years should fit if the truck has not been chopped and channeled. You will need a rubber seal to fit which window you choose to install, slider or non slider. I will be in the junk yards this week end and will measure early and late 720 regular cab back glasses to verify this. Edited January 19, 2019 by Charlie69 1 Quote Link to comment
CicliDevotion Posted January 22, 2019 Author Report Share Posted January 22, 2019 If I'm switching from a slider to a solid and the rubber seal on the slider appears to be in good shape, can I reuse it with the new solid glass? 1 Quote Link to comment
Charlie69 Posted January 22, 2019 Report Share Posted January 22, 2019 Seals ere different I believe. I will compare my 85 ST slider with my 86 solid window today. Both of these trucks are King Cabs as is my 84. I will be in the yards on thursday and if there are regular cab trucks with solid and sliding windows I will compare them. 1 Quote Link to comment
TheKelsoKid Posted January 23, 2019 Report Share Posted January 23, 2019 On 1/21/2019 at 9:19 PM, CicliDevotion said: If I'm switching from a slider to a solid and the rubber seal on the slider appears to be in good shape, can I reuse it with the new solid glass? On the KC at least, the slider seal is the same for the solid. Just swapped mine a couple days ago. SUPER easy. Popped out slider window, put old seal on the new solid glass, popped new window in. 2 Quote Link to comment
CicliDevotion Posted January 23, 2019 Author Report Share Posted January 23, 2019 9 hours ago, TheKelsoKid said: On the KC at least, the slider seal is the same for the solid. Just swapped mine a couple days ago. SUPER easy. Popped out slider window, put old seal on the new solid glass, popped new window in. Right on. Thanks. Any tips on popping out the slider? Did you just use some tape-wrapped putty knives/scrapers and work your way around the corners? 1 Quote Link to comment
TheKelsoKid Posted February 10, 2019 Report Share Posted February 10, 2019 On 1/23/2019 at 7:55 AM, CicliDevotion said: Right on. Thanks. Any tips on popping out the slider? Did you just use some tape-wrapped putty knives/scrapers and work your way around the corners? Hey sorry I haven't checked my notifications in a while.. And just a putty knife and a buddy. Start from the corner from the outside while someone pushes from the inside. You will be surprised with how easy it comes out. Also don't be afraid to put a lot of pressure. At least my window flexed enough to come out easy. 2 Quote Link to comment
