Justinkase72 Posted December 18, 2018 Report Share Posted December 18, 2018 I've got an 84 Datsun 720 long bed that is currently my project and ran into a bit of an issue. I want to add air shocks to my truck in the rear but the only ones made for my truck are currently discontinued by Gabriel. I found a set through Monroe but they are for a different vehicle. Everything about the two are similar (eyelet on top and stud on bottom). The collapsed and extended length are the same as well. Will they work? 1 Quote Link to comment
datzenmike Posted December 19, 2018 Report Share Posted December 19, 2018 By your description, they will fit the truck. As for 'will they work', the shock may be firmer or softer and depends on what vehicle they were intended, the lift is how much air you put in them so that will work. 1 Quote Link to comment
