NVFireFighter Posted December 17, 2018 Report Share Posted December 17, 2018 So I've done the search thing and can find nothing current on replacing the shifter bushings.....mine has a very sloppy condition and I'd like to replace it. Does anyone offer the rebuild kit? Thanks! Quote Link to comment
NVFireFighter Posted December 17, 2018 Author Report Share Posted December 17, 2018 Did find this though.......hahaha https://www.bamshiftsstore.com/collections/bam-handles/products/mount-fuji?variant=8099327508578 I'm gonna get it..... Quote Link to comment
datzenmike Posted December 18, 2018 Report Share Posted December 18, 2018 https://ratsun.net/topic/37751-shift-lever-bushing/ https://ratsun.net/topic/67842-just-did-the-chrysler-door-hinge-shift-bushing-mod/ https://ratsun.net/topic/59186-sloppy-shift-lever/ https://ratsun.net/topic/47452-shift-lever-bushings/ https://ratsun.net/topic/35578-shifter-bushings/ Bushing set... https://www.ebay.ca/itm/GENUINE-DATSUN-240Z-260Z-280Z-280ZX-TRANSMISSION-SHIFTER-BUSHING-REPAIR-KIT-OEM-/162652489287?oid=312253489286 1 Quote Link to comment
NVFireFighter Posted December 18, 2018 Author Report Share Posted December 18, 2018 27 minutes ago, datzenmike said: Bushing set... https://www.ebay.ca/itm/GENUINE-DATSUN-240Z-260Z-280Z-280ZX-TRANSMISSION-SHIFTER-BUSHING-REPAIR-KIT-OEM-/162652489287?oid=312253489286 I saw this set up, but it didn't say that it will work on my truck? Just for Z's...... Quote Link to comment
datzenmike Posted December 18, 2018 Report Share Posted December 18, 2018 '78 620??? they are the same transmission. Once the engine size started getting larger and the vehicle heavier and used for carrying loads the F4W63 was a little too light so Nissan simply swapped the six cylinder 4 speed transmission in. When the 5 speed became available on the 280z in '77 it was offered as an option on the truck. 1 Quote Link to comment
NVFireFighter Posted December 18, 2018 Author Report Share Posted December 18, 2018 Thanks again Mike! Quote Link to comment
datzenmike Posted December 18, 2018 Report Share Posted December 18, 2018 The also fit the 63A dogleg and the B-210 and 210 shifters. Quote Link to comment
Thegreek Posted December 19, 2018 Report Share Posted December 19, 2018 On 12/17/2018 at 7:39 PM, datzenmike said: Bushing set... https://www.ebay.ca/itm/GENUINE-DATSUN-240Z-260Z-280Z-280ZX-TRANSMISSION-SHIFTER-BUSHING-REPAIR-KIT-OEM-/162652489287?oid=312253489286 This is the set I just used in my 620.....worked like a charm. Quote Link to comment
Seeker > 620 KC Posted December 22, 2018 Report Share Posted December 22, 2018 The pivot pin, plastic bushings, and e-clips are still available thru Nissan , but you might have to partner with someone because they sell e-clips in packs of 10; and bushings in 5 packs, when the vehicle only requires 1 e-clip, and 2 bushings . Go figure, eh? Quote Link to comment
Goemon Posted October 11, 2019 Report Share Posted October 11, 2019 I had to buy an oil pan from the dealer several years ago. It was pricey......$200.00 I think.? The tray inside mine was cracked and almost broken. Good thing I caught it when we did the transmission. Quote Link to comment
banzai510(hainz) Posted October 11, 2019 Report Share Posted October 11, 2019 shifter bushings get the meteal door hinge ones those plastic one the plastic might be so old . I had a kit and it desintagrated on me Quote Link to comment
distributorguy Posted October 24, 2019 Report Share Posted October 24, 2019 Making those bushings from brass is a really simple mini-lathe project. Then you can custom fit them for better clearances. Quote Link to comment
