vetteguy22 Posted February 29, 2020 Report Share Posted February 29, 2020 What wiper motor are you using? Quote Link to comment
rosso Posted February 29, 2020 Author Report Share Posted February 29, 2020 Slave cylinder installed: This is a 300ZX slave with the hose connection located above the bleeder so it is not hanging down. My particular installation for whatever reason of combination of VG33, EE motor mounts, and a 71C trans with the aforementioned slave - the clutch hose I had was too short. It was 9". I finally found a Dorman that is 10 3/8" long and fits fine albeit 10" might have been even better. Dorman #HP 38119 NAPA # UP 38119 or just 38119 1 Quote Link to comment
rosso Posted February 29, 2020 Author Report Share Posted February 29, 2020 21 minutes ago, vetteguy22 said: What wiper motor are you using? Stock motor - seems to work fine both speeds and I need to economize to get this done and running before I splurge on upgrades. Quote Link to comment
rosso Posted March 2, 2020 Author Report Share Posted March 2, 2020 Started to put more stuff back on the car - all new steering linkages, ball joints, and one coilover. Freed up one wiper pivot assembly - soaking the other one and hoping it can be resurrected too. Quote Link to comment
thisismatt Posted March 2, 2020 Report Share Posted March 2, 2020 Don't tighten down control arm bushing bolts until suspension is sitting at ride height, otherwise the bushing will be over stressed. Quote Link to comment
rosso Posted March 2, 2020 Author Report Share Posted March 2, 2020 The control arm bushings looked fine and were firm, and I don't have a press - so I left them alone. Once I get if back on the ground and at a new slightly lower ride height, I will adjust the sway bar end links and check the TC rods and I guess just loosen, then re-tighten the control arm bushings. Sound good? Thanks. I got a wiper pivot arm freed up today too - one down one to go. Was rusted solid. Quote Link to comment
rosso Posted March 6, 2020 Author Report Share Posted March 6, 2020 Made some time today to get all the used 280ZX brake stuff that came with the car cleaned and calipers rebuilt. I am waiting for a tie rod end to finish the driver side steering and an axle nut for same side. Bolted everything up to make sure it all fits and I have not overlooked any parts and this is the result: I am looking for a pair of 280ZX backing plates if anyone has some they don't want to use. From what I am seeing on the car, and in nissanpartsdeal.com diagrams - they have a rather thick center area that will fill the space next to the strut and keep the inner seal in place. Please PM me if you have some or have questions about what I need. I am posting in classified WTB also. Trying to clean the workbench and get some of the little new parts installed to make space, so this while waiting for caliper to dry: Black is a theme, I should have wiped the valve cover..... 1 Quote Link to comment
vetteguy22 Posted March 6, 2020 Report Share Posted March 6, 2020 I think I have some backing plates. I can check for you today if you like. Rob Quote Link to comment
rosso Posted March 6, 2020 Author Report Share Posted March 6, 2020 3 hours ago, vetteguy22 said: I think I have some backing plates. I can check for you today if you like. Rob Thanks, yes please. The flange area should be about 3mm-4mm thick, not just the thin metal as the rest of the shield. At least that's what I think it should be. I have never actually seen one. M Quote Link to comment
vetteguy22 Posted March 7, 2020 Report Share Posted March 7, 2020 Sorry I forgot to check. I’m making a note to do so tomorrow Quote Link to comment
thisismatt Posted March 7, 2020 Report Share Posted March 7, 2020 https://www.ebay.com/itm/79-83-Datsun-280zx-front-backing-dust-plates/192614059479?hash=item2cd8b14dd7:g:nCwAAOSwIUZbYN7j Quote Link to comment
vetteguy22 Posted March 7, 2020 Report Share Posted March 7, 2020 I did check this morning and I don’t have the front backing plates, only the backs for a 280zx. Have plenty of 510 though, haha. sorry I couldn’t help. Rob Quote Link to comment
rosso Posted March 8, 2020 Author Report Share Posted March 8, 2020 (edited) Driver side going on the car... ...not being IN the car This is the first I have seen the inside of the car - it has been full of parts since I got it over a year ago. Needs a bit of cleaning but overall in excellent condition. Can anyone tell me where I store the scissors jack, jack handle, spare tire screw rod and crank handle? The long rod apparently fits in two clips that run along the drivers side door bottom. Anyone able to confirm that and the other stuff? And it's the first picture of me and the car together. <big grin> Edited March 8, 2020 by rosso 1 Quote Link to comment
rosso Posted March 11, 2020 Author Report Share Posted March 11, 2020 Moving on to one of the next things to check - the fuel tank, lines, evap sytem etc and to get ready to install an electric fuel pump. I pulled the cargo panel out and found everything in pretty good shape: New large filler hose and it's very flexible, new smaller hose at rear, and the other original hoses are all in okay shape with a slight bit of rusting around the clamps. I plan to leave it alone until I get gas in it and see if there are any leaks - otherwise I am good to go on these guys. It will become a preventative maintenance item for the future. 2 Quote Link to comment
rosso Posted March 13, 2020 Author Report Share Posted March 13, 2020 So before I closed the cargo panel I took a few minutes to see how easy it was going to be to "clean" whatever the stains were. So 5 minutes with hand polish and better enough that I can clean up when hoses are off for preventative maint in the future Also working on the firewall.cowl area - here's the hood spring mounting bracket. De-rusted, primed, paint and clear coat. Blended with existing paint on bracket and a pretty good match. And the other side by the wiper motor. Struts are back in too. 1 Quote Link to comment
thisismatt Posted March 13, 2020 Report Share Posted March 13, 2020 Have you cleaned out the center cowl vent? Quote Link to comment
vetteguy22 Posted March 13, 2020 Report Share Posted March 13, 2020 Looking really nice. Quote Link to comment
rosso Posted March 13, 2020 Author Report Share Posted March 13, 2020 5 hours ago, thisismatt said: Have you cleaned out the center cowl vent? Yes, I posted about the center drain in December 2018 I think in a separate thread. Where the drain comes out: What came out onto the garage floor: 1 1 Quote Link to comment
Stitebunny Posted March 14, 2020 Report Share Posted March 14, 2020 Nice job! It’s all looking great! Quote Link to comment
rosso Posted March 14, 2020 Author Report Share Posted March 14, 2020 Thanks Rob and StiteBunny - I appreciate the support and it helps keep me going. Doing all the work by myself is sometime challenging but I feel much better about the project since I got the motor and trans installed. If I get a bit down, I just look at the VG33 sitting in there and all is better. 🙂🙂🙂 1 Quote Link to comment
rosso Posted March 22, 2020 Author Report Share Posted March 22, 2020 Decided to clean the garage today - because it was dirty and because I could do this Overall coming along, still lots to do and I don't have the rebuilt caliper/brakes all sorted yet. Coilovers are adjusted - about 1/2" high I think but I will let them settle a bit and still have a few pounds of things to add on the car. The car is a roller at least and I can push it in and out of the garage if needed now. Not looking bad for an old girl - doncha think? Painted ZX wheels are okay until I have all the other stuff sorted and using the car for a daily driver. One issue I was not expecting is the passenger side tire rubs the strut/coilover. Driver side is fine. So not sure what is going on. Like other project members, the car has been on jack stands for so long it is really something to see it at normal ride height. 🙂 1 Quote Link to comment
rosso Posted March 23, 2020 Author Report Share Posted March 23, 2020 Back in the garage and test fitting the distributor, The speedo cable is connected down at transmission and I need to run it into the dash (when I redo the dashpad, soon) 2 Quote Link to comment
vetteguy22 Posted March 23, 2020 Report Share Posted March 23, 2020 Looking good. You’re doing a great job documenting your progress. I appreciate the updates. 1 Quote Link to comment
rosso Posted March 26, 2020 Author Report Share Posted March 26, 2020 Decided to take a break from trying to figure out problems and getting parts ordered and work on how the car looks. Took off the front bumperettes; bam with bumperettes I originally rather liked them since they were in good shape and it's a wagon; however, looking at the clean bumper I have changed my mind. Clean = moar better. 1 Quote Link to comment
