datzenmike Posted December 5, 2018 Report Share Posted December 5, 2018 22 minutes ago, i need help & guidance said: i found this rebuild kit with accelerator pump it has the part i need .. total is $ 39 That's a good price if re-building it, a bit steep just for one part. 19 minutes ago, i need help & guidance said: i also found this carb . but it is for the z24 engine it says carb 3 hours ago, datzenmike said: The 720 gas engines were all Hitachi. The L20B was 340 or 30/34 The Z22 was a 342... or 32/34mm The Z24 was a 384 or 34/38mm bore. Unfortunately one of the stud holes on this carb does not match all the others so it won't swap. I just measured and confirmed this. The accelerator pumps are likely all the same but just to be safe order for a Z22 truck.. Also too cheap to be good. It says from Australia but I bet it's trans-shipped from China. A factory carb, if you could find one today, would be well over $860 Quote Link to comment
i need help & guidance Posted December 6, 2018 Author Report Share Posted December 6, 2018 i passed the smog test !!! 1 Quote Link to comment
weldingrod Posted December 6, 2018 Report Share Posted December 6, 2018 Re; fuel check valve. Two lines to carburetor- one from fuel pump, other returns to check valve and into tank. Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 egr needed new gasket Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 accelerator pump was bad Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 the replacing Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 tried to clean old parts Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 had to file (smooth) the old nylon sleeve thing which surrounds the pump, since the rebuild kit does not include 1 of these Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 putting new pump in Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 new pump installed . Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 page 1 of sheet that came with new pump Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 page 2 Quote Link to comment
i need help & guidance Posted December 7, 2018 Author Report Share Posted December 7, 2018 page 3 Quote Link to comment
datzenmike Posted December 7, 2018 Report Share Posted December 7, 2018 I think that plastic is bakelite. It's also used on the piston on the front oil bath struts... Quote Link to comment
