Icehouse Posted February 1, 2019 Report Share Posted February 1, 2019 We put a new LSD in our racecar. It was loud as hell for a while. Even with the additive. I can't remember what the breakaway was. I'm thinking 45lbs. My R190 LSD which I thought was wore out is set at 25lbs. If I do a very tight barrel at the autox it can end up with one tire fire. From what I now understand the initial breakaway can help this. I'm not sure if I want to up it though. It will in turn effect the turn in. Which my car does quite well. Quote Link to comment
datzenmike Posted February 2, 2019 Report Share Posted February 2, 2019 A welded differential adds huge under steer. Likewise the higher the break away the more under steer. Also won't the tires both break traction when accelerating out of a turn (assuming you have the power) and throw the car into over steer? Everything....... affects everything else. Quote Link to comment
metalmonkey47 Posted February 19, 2019 Report Share Posted February 19, 2019 (edited) These things are a bit clunky by nature, you may give the Red Line friction modifier a try. We use it in house on just about every CLSD to help reduce a bit of the noise, it dramatically reduces low speed chatter. https://www.z1motorsports.com/oils-and-lubricants/red-line-oils/red-line-limited-slip-friction-modifier-break-in-additive-p-8680.html Edited February 19, 2019 by metalmonkey47 Quote Link to comment
