drawks Posted November 21, 2018 Report Share Posted November 21, 2018 I've been staring at pictures of this engine lately and I can't help but think it would be a hot swap into a dime. * There are a million wrecked base model 2015-2018 mustangs in the world, which means this motor is plentiful in the wild * unlike many direct injection motors Ford sells an ECU package meant for swapping this guy into a car without requiring a million body harness gizmos and a computer controlled transmission * It has a rear sump oil pan * the factory 6 speed tranny for it is a single OD unit so you get close ratios for the first 5 speeds * if the mustang 6 doesn't fit well as a swap in a 510, the block has the duratec inline 4 bolt pattern which makes the common m5od r1/hd trans a direct bolt on as well as the NC miata 6 speed, both of which have a much further forward direct mount shifter * in factory trim with the mustang ECU this motor is good for 310hp/350tq and word is that the ford standalone "powerpack" puts out more power but requires 91 octane (the mustang ECU will run on 87 octane, but will dynamically detune the engine down to 270hp) Anyone know of a 510 running one of these engines? Aside from "Not A Nissan" does anyone see any obvious reasons not to use this motor? 1 Quote Link to comment
Z-train Posted November 22, 2018 Report Share Posted November 22, 2018 Extensive sheet metal work to firewall & floor. Possibly being forced to delete entire heater system. Quote Link to comment
drawks Posted November 22, 2018 Author Report Share Posted November 22, 2018 Is the block + accessories that much longer than an l/ka? Is the transmission that much larger? Are you speculating or have you measured it? Quote Link to comment
drawks Posted November 22, 2018 Author Report Share Posted November 22, 2018 I can't figure out how to attach an image to a post, but I have a mechanical drawing of the 2.3 crate motor from ford and it looks dimensionally pretty comparable to an sr20det: 512.5mm from rear of block to front of pullies 659.5mm overall length including all accessories as dressed 665mm total width including all accessories, turbo, manifolds 301.2mm passenger side to centerline w/accessories as above 363.9mm driver side to centerline w/ acc 752mm total height from bottom of sump to highest point the 6 speed getrag tranny is 677mm from bellhousing face to rear mount I'm having trouble finding good dimensions for a dressed sr20det, but seeing number like 22.5"(571mm) from front pull to rear of block and 25"(635mm) wide including manifolds and turbo. Quote Link to comment
scooter Posted November 23, 2018 Report Share Posted November 23, 2018 buddy of mine has a focus RS and this motor looks compact... HEAD GASKET HAHAH Quote Link to comment
drawks Posted November 24, 2018 Author Report Share Posted November 24, 2018 Oh schnap, I don't even know how I didn't notice before, the exhaust is on the passenger side of this motor too! So no crazy engineering to accommodate the turbo, steering and master cylinders all wanting to go in the same place. The more I look at this engine the more I want to see one in a dime! Quote Link to comment
dukerollo Posted November 24, 2018 Report Share Posted November 24, 2018 Do it! Quote Link to comment
hosestop@msn.com Posted November 24, 2018 Report Share Posted November 24, 2018 FORD Quote Link to comment
datzenmike Posted November 24, 2018 Report Share Posted November 24, 2018 On 11/21/2018 at 1:56 PM, drawks said: Anyone know of a 510 running one of these engines? Aside from "Not A Nissan" does anyone see any obvious reasons not to use this motor? this... 1 hour ago, hosestop@msn.com said: FORD Always mate within you own species. You could have sex with a sheep, but people don't like you near them much afterwards. 1 Quote Link to comment
drawks Posted November 24, 2018 Author Report Share Posted November 24, 2018 4 hours ago, datzenmike said: Always mate within you own species. You could have sex with a sheep, but people don't like you near them much afterwards. Seems a bit narrow minded to me, Nissan hasn't made a modern performance oriented 4 cylinder engine in a decade and even the venerable sr20det puts out pretty pedestrian 220~ hp in stock trim and really wants a bunch of parts/work to reliably put out the same power as the EB Ford motor. Heck people have been swapping non-nissan motors in 510s for ages, Mazda rotary, Buick 215, etc heck I recall turbo Tom swapping a GM v6 with a couple turbos in the early 90s. 2 Quote Link to comment
datsunrides Posted November 24, 2018 Report Share Posted November 24, 2018 Do what you want, it’s your ride. With a little thought I’m sure you can do it with reversible mods. I have a Mits V6 in a Corolla wagon and a Mazda 4 banger in my 1200. Thinking about dropping a LS in one of my Colts too. No stranger to cross-pollination. 2 Quote Link to comment
drawks Posted November 24, 2018 Author Report Share Posted November 24, 2018 That's the discussion I was trying to avoid ? so... Aside from worrying about what brand of motor it is, anyone have any experience with the 2.3 ecoboost? How about the transmission? Quote Link to comment
datzenmike Posted November 25, 2018 Report Share Posted November 25, 2018 When you start swapping in newer engines, your Datsun becomes less of a Datsun and less of a classic car. If you use a non Nissan engine you are even less of less. Go ahead, someone has to. I get it. 1 Quote Link to comment
tr8er Posted November 25, 2018 Report Share Posted November 25, 2018 If you swap in a Prince, you get extra points 1 1 Quote Link to comment
bananahamuck Posted November 25, 2018 Report Share Posted November 25, 2018 Prince Ecoboost Have any of you priced the stand alone harness ?? Holy dangling dog balls Batman !! . 1 Quote Link to comment
drawks Posted November 25, 2018 Author Report Share Posted November 25, 2018 3 hours ago, bananahamuck said: Prince Ecoboost Have any of you priced the stand alone harness ?? Holy dangling dog balls Batman !! The standalone is really the same ECU as in the mustang, only difference is it has the anti-theft features disabled so you can use a conventional ignition switch. At any rate, I spent some time today talking to some shops that work on these engines and it turns out that most of them aren't using the 2.3 block because it is an open deck and has some problems even at stock power levels. So, long story short it turns out that at the end of the day the cost to build a reliable 300hp ecoboost isn't so much different than just building a turboed sr or ka. The packaging with the passenger side exhaust is pretty rad, but I'm thinking probably not rad enough to reinvent everything to do the swap. So, back to the drawing board I guess. Quote Link to comment
datzenmike Posted November 25, 2018 Report Share Posted November 25, 2018 Keep your Datsun, pure Datsun 1 Quote Link to comment
Icehouse Posted November 25, 2018 Report Share Posted November 25, 2018 8 hours ago, drawks said: Seems a bit narrow minded to me, Nissan hasn't made a modern performance oriented 4 cylinder engine in a decade and even the venerable sr20det puts out pretty pedestrian 220~ hp in stock trim and really wants a bunch of parts/work to reliably put out the same power as the EB Ford motor. Heck people have been swapping non-nissan motors in 510s for ages, Mazda rotary, Buick 215, etc heck I recall turbo Tom swapping a GM v6 with a couple turbos in the early 90s. I wouldn’t be opposed to a different 4 cylinder engine. I agree Nissan has dropped the ball on making a good one. Although the last RWD SR made 260hp and the last FWD SR made 280hp. Which is some good power. As of now I think Mazwerks holds the 4 cylinder HP record with a SR. Just saying ? I really the S2k engine. Almost had one! I gotta look up this engine you speak of. Quote Link to comment
drawks Posted November 25, 2018 Author Report Share Posted November 25, 2018 33 minutes ago, Icehouse said: As of now I think Mazwerks holds the 4 cylinder HP record with a SR. LOL calling that mazwerks motor an SR is like calling a top fuel motor a Dodge hemi. Full custom everything, aside from some shared dimensions and geometry I don't think that thing has a single stock sr20det part on it. I do like how it picks up 800hp in a 300rpm window when that monster turbo finally gets spun up tho ??? Quote Link to comment
bananahamuck Posted November 25, 2018 Report Share Posted November 25, 2018 2 hours ago, drawks said: The standalone is really the same ECU as in the mustang, only difference is it has the anti-theft features disabled so you can use a conventional ignition switch. I was only commenting on price Ford wanted for it,,,,,,, $1699. and it said it was normally $2050. (?) . 1 Quote Link to comment
Z-train Posted November 25, 2018 Report Share Posted November 25, 2018 On 11/21/2018 at 10:07 PM, drawks said: Is the block + accessories that much longer than an l/ka? Is the transmission that much larger? Are you speculating or have you measured it? Based on a 327/350 into a 620. Simple logical conclusion. Quote Link to comment
drawks Posted November 25, 2018 Author Report Share Posted November 25, 2018 50 minutes ago, Z-train said: Based on a 327/350 into a 620. Simple logical conclusion. Are you really comparing a small block Chevy V8 into a 720 pickup to a turbo charged direct injection Ford inline 4 cylinder into a 510!?!?! You have to be trolling me right? Quote Link to comment
datzenmike Posted November 25, 2018 Report Share Posted November 25, 2018 The dime engine compartment is even smaller. Quote Link to comment
drawks Posted November 26, 2018 Author Report Share Posted November 26, 2018 I must have taken some crazy pills... Yes I understand that a 510 is smaller than a 720, but also an sbc and an ecoboost 4 are not the same size in any dimension, don't use the same transmission and have basically nothing in common. I just fail to see how the mods needed to make an sbc go into a 720 has anything to do with the swap I was talking about.... ? Quote Link to comment
datzenmike Posted November 26, 2018 Report Share Posted November 26, 2018 It might fit. Looks wider up top with a turbo no less and fairly tall. Has to fit between the two strut towers. Quote Link to comment
