BrandonS Posted November 16, 2018 Report Share Posted November 16, 2018 (edited) Is anyone running these? What are your impressions? Did you do front and back with them and if so did you just use the larger piston version for the front calipers? Considering them due to the 4 pistons, acceptable rotor range, and you can still fit them under smaller wheels (14"). Thanks ? Edited November 16, 2018 by BrandonS 1 Quote Link to comment
fivetenguy Posted November 16, 2018 Report Share Posted November 16, 2018 I run them on two of my cars. They are awesome. Only that I run them with a 12.2" rotor and only 15" and larger aftermarket rims fit over my setup. The 15" JDM wheels with a two piece barrel fit do not fit. I would think that if you run a smaller (11" or less) or stock rotor, the 15" JDM wheels would fit. 2 Quote Link to comment
BrandonS Posted November 17, 2018 Author Report Share Posted November 17, 2018 (edited) On 11/17/2018 at 12:06 AM, fivetenguy said: I run them on two of my cars. They are awesome. Only that I run them with a 12.2" rotor and only 15" and larger aftermarket rims fit over my setup. The 15" JDM wheels with a two piece barrel fit do not fit. I would think that if you run a smaller (11" or less) or stock rotor, the 15" JDM wheels would fit. Do you have them front and rear? Did you run the 1.38" pistons up front and the 1" pistons i the rear? Edited November 18, 2018 by BrandonS 2 Quote Link to comment
fivetenguy Posted November 21, 2018 Report Share Posted November 21, 2018 On one of my cars I have them on the front and rear. I believe they are in the piston sizes you've mentioned. I can go back and look at the specs if you need me to. Quote Link to comment
BrandonS Posted November 21, 2018 Author Report Share Posted November 21, 2018 If you ever think of it... no need to on my accord. Thank you for your input. Quote Link to comment
