From Farm to City Life! 1974 build thread.
LRO255
1974 Datsun 620
Purchased: Oct 5th, 2018
All Stock vin matching
Exterior: Major surface rust all over
Interior: Some weather damage
Suspension / Wheels: Aftermarket wheels "OEM wheels included"
The truck was a barn find from the previous owner. Did some minor work to get it running but he decided to go in a different route.
Luckily I was the first to contact him and got the truck for a great deal. I have been looking for a 620 for a few years now and now I'm part of the Datsun family.
My goals are to build this truck to my taste but keeping it classic. I know currently forums aren't as active like 10-15 years ago but I still think this the best way to learn and meet people in the same community as you. I will keep updating on here while I still own this truck, which I hope is forever. And now for pics!
0AF1E88B-0CDD-4F5B-B688-4CF460456615_zps
79427FBD-899C-414B-AEB2-C9FCFDCF938F_zps
25DAE4B0-C042-457F-AF3A-CE7939F100FD_zps
0232F191-31AF-4487-8DEE-7DC644E289C5_zps
5C83CA1D-E7BA-4794-8306-15B551DA58A1_zps
  • Like 6
  • Replies 19
On ‎10‎/‎30‎/‎2018 at 8:00 AM, JohnnyBlaze said:
Was this on Craigslist, maybe in the Carolina's?  Looks like one I saw on there recently.  It appears to be pretty solid and has way less rust then my 78 I picked up in PA last month.  Mine has the same or similar wheels.  Have fun with it.
Yes it is!
23 hours ago, banzai510(hainz) said:
Oh man thats cool
I would just get it running and roll it like that.
Masybe soem better wheels or stock wheels redone with small white wall
That's my short term plan. Running good enough to drive back and forth to work. And a clear to the body to hold the rust from getting worst.
Finally made it to the city: Oct 12th, 2018
Left on the 10th
1C4D77AC-89C5-4BF4-B0C8-F0D3616ADF69_zps
Two days later made it home.
1F05EFA8-9F59-4DE5-BC3F-52631E9FE7D6_zps
A992D78C-9329-4284-B1B8-E528301070B4_zps
D12F504C-421B-4FA8-B071-E53BD5FADD35_zps
First job was to check what needs repair and remove that bumper.
BAA17299-B503-4941-849C-A96995940BDA_zps
8170B4A4-DAE0-430B-A119-811E073A4E45_zps
90C4647F-F1F2-4DDD-A0C0-F7F71EFE0DE1_zps
Bumper took some time to remove due to the rust but it finally came out.
Is that bumper some how an OEM option?
D27E193B-3363-4C2A-BF60-39F384DAB5B0_zps
698E808F-9655-48F7-8FA2-6A9BB21A8FB8_zps
Also gave the muffler a new custom tip.
More coming soon!
Some 620s came without a rear bumper to exploit a legal loophole and avoid the chicken tax. (look it up) Technically the truck is shipped without one and not entirely built overseas and a bumper is added here to complete it.
Yes, I know that most didn't come with rear bumper. But I was wondering if Datsun/Nissan dealerships used to offer bumpers like the one I have?
Well so far I done a few things to get it running as normal as possible. Ran in to two problems and hopefully you guys can help me out with one of them.
CE2531B3-2DE9-4210-A075-440BE9556848_zps
I removed the gas tank which it was fairly easy but I did end up breaking 3 bolts.
I opened it up the next day and I notice how bad it is on the inside.
I did purchased the chemicals to clean it myself but I decided to get a professional to do the job instead.
948617CF-8281-4366-B091-9FEA4E7A2A11_zps
6BDC892F-3EBD-4D3F-8156-F4C817D44F6E_zps
CA21E952-3D70-49CF-99E9-2B471FD36419_zps
8CEC9AB4-CCCE-4ACC-A7AB-07AFEA0C582F_zps
I also flushed the engine and coolant fluids. Noticed that I have a leak on the radiator and water pump. Replaced the radiator and soon I will do the same to the pump.
Replaced the thermostat while I was at it but one of the cover bolt took me just about 3 hours to remove.
B64DB4F8-8AEB-4EDB-A239-3855D1E74FD4_zps
16C704F6-EED0-43A0-AF9B-A3551CBBBCFB_zps
DE4DD940-AD61-4A4F-A8B6-03E45F3E7B53_zps
C025801A-CA0B-461D-841A-9389FB26308C_zps
7B66CC7C-F92B-4D4C-B99E-BB4F0498EE4E_zps
EE69691F-384E-4A21-BE1B-138FEC317167_zps
095438A6-C658-4F45-BED0-B636459E386A_zps
I also replaced some of the vacuums lines and notice a few missing.
*So here is where I need some help*
The following locations are missing hoses. By any chance anyone knows?
6EDF6460-2B8D-4F8A-94D0-14B5F7168A7A_zps
76F743BC-9562-44EF-A1D2-98323A219062_zps
40A50894-E842-4EEE-8D5D-27AEC029B4A3_zps
After some brakes adjustments and new air filter I drove it around and it ran ok.
High Idle on start and too low on drive. Shutoff on me a few times. I hoping replacing the missing hoses will help on that.
D381D2F9-6B49-4C73-BC7F-1BD1E4638465_zps
8671EE64-A3DA-4E6E-AA9A-189DF7D9F448_zps
AAF7CF25-5D16-4202-94D6-52DF38821EA7_zps
92F474C7-D819-4423-9042-CD6A8F61BA9F_zps
And finally, I removed the old tires of the oem wheels to clean them up for new tires.
EF765A79-29BE-4966-A30A-B562B4957851_zps
19D679AD-1F52-4AB2-A61D-3C90F2B826F1_zps
01BBDC70-464C-45C4-9C86-EB3F455C099A_zps
Next step is to replace the muffler.
I like the stock wheels and hubcaps my self
use anti seize on those thermostat bolts. YOull never have that proplem again., matter of fact everything. I do the water pump bolts also,intake exahust ect....
the lower housing with the temp sender is a pain if its stuck also.usually cracks the housing thus leaking.
rusty gas can cause the idle jet to plug so run 2 fuel  filters(the stock one and a in line one) at first till you think its clean gas to the carb.
If stock carb works just rock it. Iwould get a walker queit muffler maybe just up size the pipe to 2 inch
I see you have a red Opitma. I had bad luck with them
I like this truck esp in NY. Not many there
Edited by banzai510(hainz)
If that's the original radiator, don't get rid of it. The brass ones are getting harder to find these days and are totally rebuildable, not t mention stronger than the aluminum/plastic radiators.
I love this stage of the job. Once you get everything back and installed, it's always fun to hear it fire and get some heat into it. I usually fill them with water only and let them idle for a few hours in the driveway, then flush out the crap before putting in the coolant.
Every outside bolt will have anti-seize for sure. I'm currently using a portable fuel gallon since I knew in advance that the gas tank needed some attention. So far the red top is working perfectly. no complains so far. My goal is to keep the current carb but if it gives me too many problems I'm going weber. And yes it is nice having this truck in NY. Not to many like it here. I also so love the OE wheels.
On ‎11‎/‎15‎/‎2018 at 3:11 AM, Spawn said:
LRO255, where are you located in NY?  Are you in the city or somewhere Upstate?
NYC, next time you come down here let me know.
According to the last owner the truck was sitting for over 20 years. As you could tell by the picture of the OE wheels. The radiator was to far gone also. Leaking from every area. Plus in the future it will most likely have a custom rad. Coolant is completely flush now.
  • Like 3
  • 6 months later...
Nice project LRO,
The factory did offer the small bumperetts, so desirable and petite, that fit on 520's and 620's.
That giant ungodly step-bumper was popular with the camper and tow crowd. These were often custom jobs by camper companies.
If you can snag a set of the small factory ones they would sure look swell...
I originally had them on my (bought new in 1970 as a senior at Lynwood High)521, then transfered them over to my '79 King Cab...perfect style IMO
Vicdat
