Tru-align steering knuckles?
https://www.ebay.com/itm/Rare-Tru-Align-Kit-4052-1968-72-510-SSS-74-79-B210-610-710-Handling-Improvement-/352034338985?_trksid=p2385738.m4383.l4275.c10
Da faq?!?!
these dont fit my application, but i stumbled on them looking for a cheaper alternative to ermishes lowered steering knuckles.  Thought someone else might want to buy them!
Anyone have anymore info or background on these?  the instructions look like a decent amount of effort went into these pieces, I dont claimed to be a datsun parts specialist by any stretch.  But these still seem very peculiar and rare. One off almost?
  • Replies 3
Interesting parts.  Looks like the steering knuckle locates on the ball joint with an eccentric that can add camber and/or caster to the strut depending on how it is rotated. Modern camber plates and adjustable T/C rods make these obsolete, so I would file these under historical interest only. Totally different end goal than the re-arc'd steering knuckles. I think Ermish gets them from DP Racing. Not many options here, I'm afraid. Pay up or try to bend and reharden your own.
  • 1 month later...
Totally different then a camber plate or pulling the TC rod forward.  This will adjust your scrub radius,  ackerman, and trailing caster offset (not sure the exact term for that)  Re-arc'd steering knuckles are to correct bump for cars with added caster.  You can just replace the tie rod with a hiem joint and shim out the bump.
