TResistance Posted October 28, 2018 Report Share Posted October 28, 2018 Hey buddies! I have a problem with my Datsun 160j, aka Violet. ❤️ Since a half year, it consume a lot fuel. I very tired. I tried driving slow and don't work. I paying a specialist to rebuild the carb and the fuel consume is the same. But, an a one week ago, tired I remember what i have a two carbs and i decided to reemplace a main jet, main air... But the car is very slow. Today, i decided a change a pieces, some wear and old. But when i start the car, in "low" pass much fuel, on high works fine. And sounds better ? But tried to economice fuel ?. And tried to recovery the same config but on low seems like he's drowning and don't work ? I listed a main jet's, main air i have, to see if you guys can a help me decide where each of the pieces in my carburetor goes. ? I live in Mexico's City, on a 2200 meters above sea level. My Carb (up) My Carb (down) Jets The last jet's, they go in the part below. Which config do you recommend? Quote Link to comment
datzenmike Posted October 28, 2018 Report Share Posted October 28, 2018 It's very easy to get the secondary jet in the primary side. The primary jet is always smaller than the secondary. For example, something like 99 and 160... well at sea level. At over 7200 feet the jets should definitely be smaller because the air pressure is lower and the engine will run very rich. Is your choke turning off when warmed up? Quote Link to comment
TResistance Posted October 28, 2018 Author Report Share Posted October 28, 2018 10 minutes ago, datzenmike said: It's very easy to get the secondary jet in the primary side. The primary jet is always smaller than the secondary. For example, something like 99 and 160... well at sea level. At over 7200 feet the jets should definitely be smaller because the air pressure is lower and the engine will run very rich. Is your choke turning off when warmed up? -- thank you, datzenmike for your reply don't have a electric choke. ? So, do you recommend a jet's like these (in order of my pic) Primary | Secondary 46|48 60 w/5 holes | 60 w/3 holes 120 | 200 80 | 90 Sorry I don't know a names of the Jet's. ? Quote Link to comment
datzenmike Posted October 28, 2018 Report Share Posted October 28, 2018 The primary jets go in these holes under the fuel bowl. Generally the primary (top one) is around 100 and the secondary (bottom) about 150. So is this the original carburetor? Doesn't look like it. What engine and what size do you have in your 710? Quote Link to comment
TResistance Posted October 28, 2018 Author Report Share Posted October 28, 2018 Hey buddy, thanks. I don't have a 100 and 150. I trying with 98 and 145. Yes, is the original carb. Or i think that. ? Is a 1600 (1595cc) japanesse. All my live to buy parts i say: It's a 1600. I seen a many configurations on engines. And the other two carb are nikki. Quote Link to comment
datzenmike Posted October 28, 2018 Report Share Posted October 28, 2018 L series then? Over head cam? I would think 98/145 would be a start at sea level. Make sure the smaller jet in on the side closest to the valve cover. Quote Link to comment
TResistance Posted October 28, 2018 Author Report Share Posted October 28, 2018 Old pic, this is my engine No. I don't have lucky. Or maybe 80|98. Try to buy tomorrow in case to use. Quote Link to comment
TResistance Posted October 28, 2018 Author Report Share Posted October 28, 2018 xD I learned some new today xD So, the carb is ok for this engine? The jet config is the same or change? Quote Link to comment
datzenmike Posted October 28, 2018 Report Share Posted October 28, 2018 The last J series engine here was '69. A J13. I've seen them but don't know much about them. Are all your jets out and mixed up?? Quote Link to comment
TResistance Posted October 28, 2018 Author Report Share Posted October 28, 2018 I know, Mexico's is slow. But is a great engine. Yup, out and mixed. Think i have a problem. Perhaps if use at same principal? low numbers and medium numbers to Primary and Secondary.. Quote Link to comment
datzenmike Posted October 28, 2018 Report Share Posted October 28, 2018 I don't know, try it. Quote Link to comment
G-Duax Posted October 28, 2018 Report Share Posted October 28, 2018 Keep in mind, that other things play into fuel delivery. If it had been running fine, then started to run rich, my bet would be on the inlet needle % seat, and float level. Do you have a new inlet needle & seat ? Have you set the float level to factory specifications ? 1 Quote Link to comment
TResistance Posted October 28, 2018 Author Report Share Posted October 28, 2018 It's done, buddies. Today trying with one config, start the engine and i can use to the around the 16 millages. In the main jet (down) used the config 80 | 98 but, to press the accelerate the car is goes off. So, i used 98 | 130. And works finally. Thank you very much for the information and the time for explain me. Now I understand better the operation of the carb. Config Quote Link to comment
