zewiz Posted October 23, 2018 Report Share Posted October 23, 2018 Looking at buying a b210 and current owner says the entire motor, except lifters, was replaced. Head was machined a14 motor Any specific type of questions or concerns I should keep an eye out for? Quote Link to comment
datzenmike Posted October 24, 2018 Report Share Posted October 24, 2018 Odd. So he replaced the old engine but kept the old lifters for the replacement engine? Odometer turns over to 00,000 after 99,999 so any reading could be a over 100,000 or even 200,000 miles. Take for a drive. Check the dip stick. If oil is dirty it probably wasn't maintained very well. Not a reason for not buying... just saying. Should start easily and restart when hot. Should not have a blue cloud puff out the exhaust on start up or when driving. Should not over heat. Should not make mysterious engine, transmission or rear end sounds. All electrical should work. (no light switch for a horn) wipers, heater, 4 way, headlamps, brake lights etc. All glass in good shape. Look under the engine, Oil leak on ground? Things to note but can be replaced/fixed.... Uneven tire wear on the front. Steering wheel looseness, poor steering Drive-line vibration, U joint or wheel balance. Mismatched tires Burned out bulbs Poor braking, pull to one side. Poor handling, shocks. Quote Link to comment
zewiz Posted October 24, 2018 Author Report Share Posted October 24, 2018 My apologies, I described this very poorly :oops: the motor was rebuilt, all new parts except he kept the old lifters in there. Apparently the mechanic helping him ensured him they were in great shape and wasn’t* necessary to replace thanks for responses! Quote Link to comment
datzenmike Posted October 24, 2018 Report Share Posted October 24, 2018 I was just kidding. Welcome to Ratsun and vintage car ownership. I doubt there are many Bs around you so it's best to get the most complete example you can afford. 1 Quote Link to comment
zewiz Posted October 24, 2018 Author Report Share Posted October 24, 2018 Car seems to be in pretty solid condition. Newly rebuilt engine, new brakes all around, new clutch assembly, carpet inside is refreshed and new. Only complains of a slight lifter noise when car idles after a while..says it’s quiet when driving. There are a few spots of rust here and there, the floor pans required small patches when the carpet was out. Surprisingly low rust in crucial areas. Original gas tank rusted out so he swapped a 20gal tank into it from some other vehicle..this one makes me scratch my head honestly lol Doors and windows all intact..seals are good. All the electronics work..original wiring harness was eaten up so he swapped a new one in from a parts car donor (‘77 hatch) its not cheap but I suppose with all the work that’s done to it, the price is reasonable. Quote Link to comment
Stoffregen Motorsports Posted October 24, 2018 Report Share Posted October 24, 2018 These lifters aren't like Chevy lifters. They don't need replacing at every rebuild. They are rock solid, so I wouldn't worry about it. 1 Quote Link to comment
Tom1200 Posted October 26, 2018 Report Share Posted October 26, 2018 +1 on not replacing the lifters. My so called "back-up" race engine is pretty mildly tuned, it's an A12GX motor and the lifters are the ones that came with the motor, it's a JDM import motor we bought in 1994. It has something like 25 race weekends and probably 50 track days. The motor is routinely buzzed to 8200 rpm. 1 Quote Link to comment
zewiz Posted October 26, 2018 Author Report Share Posted October 26, 2018 Thanks for the info Tom How much should I be concerned when the owners tells me you can hear what sounds like one of the lifters not pumping all the way at idle? No noise issues when revved or running, just at idle. Quote Link to comment
Stoffregen Motorsports Posted October 26, 2018 Report Share Posted October 26, 2018 I think you should be concerned that the owner doesn't know what he's talking about. These are not hydraulic lifters and they don't pump up. If there is a valve noise, it's likely the valves are out of adjustment. How many miles are on this engine? Ever hear of the bathtub curve? New motors have high risk of failures. Motors that have 10K miles on them have far less risk. Motors that have 200K miles on them have high risk again. Quote Link to comment
datzenmike Posted October 26, 2018 Report Share Posted October 26, 2018 6 minutes ago, Stoffregen Motorsports said: I think you should be concerned that the owner doesn't know what he's talking about. Most excellent advice. I think the earliest hydraulic 'lifter' was on the '83 (or very late) 280zx. It worked but replacements are NLA when they go bad. Quote Link to comment
zewiz Posted October 26, 2018 Author Report Share Posted October 26, 2018 This engine was rebuilt approximately 1500 miles ago.. before rebuild in area of 165k miles on engine. It admitted to having help from a family friend mechanic on the rebuild. Hence this guy is the one who suggested keeping the original lifters in it. I have not seen this vehicle yet, it’s 4 hours away and am trying to get a day together with Current owner. So you’re probably right on the noise..he didn’t mention it being a valve, but that’s not too big of an issue. This bathtub curve you mention is the reason for this thread..I’m slightly worried that it’s so freshly rebuilt. With rebuilds it’s either amazing or devastating it seems Quote Link to comment
Stoffregen Motorsports Posted October 26, 2018 Report Share Posted October 26, 2018 1500 miles is outside the danger zone for most things. Bearings can still be affected, but generally speaking, if it's gone 1500 miles, it's probably in the clear. 1 Quote Link to comment
zewiz Posted October 26, 2018 Author Report Share Posted October 26, 2018 Thank you fellas for the input. I’m usually more in tune with what to look for, but I believe the 4 hour one way travel is making me overthink many things Quote Link to comment
