Dirtyowlnumber4 Posted October 20, 2018 Report Share Posted October 20, 2018 Sorry for all the threads fellas i don't know how electricity works Hooked up a new fuse box everything is working great except the running lights, which are always on. I figured i probably wired something wrong so i took all the lights wires off of the fusebox. But even without any connection to the fusebox they are still going. Could it be a bad switch? I didn't think they'd be able to work if they had no power from the fusebox. Extra: the running light and headlight fuses are what melted my old fusebox maybe the wires are bad somewhere Quote Link to comment
banzai510(hainz) Posted October 21, 2018 Report Share Posted October 21, 2018 pull the light relay in engine comp and see if light goes out. What does this mean? i HAVE NO CLUE. but should go out. Jap cars use a switchble ground so the power is always thru the fuse box and when the switch is pulled it puts a ground on the circut thus you have POWER. was fuse boxes exactly the same. the power bar under neath? if switch bad it would ohm out with a meter the same as in the off position like a SHORT(circut) Quote Link to comment
Dirtyowlnumber4 Posted October 21, 2018 Author Report Share Posted October 21, 2018 If it has a light relay I can't find it. Switch seemed good Here I drew a shitty diagram of my fusing Wouldn't be surprised if something is wrong here im no electrician. Quote Link to comment
Dirtyowlnumber4 Posted October 21, 2018 Author Report Share Posted October 21, 2018 All right i hotwired some stuff together and got things working ill just get some inline fuses and try to make it look halfway decent lol thanks chaps Quote Link to comment
