Smardo Posted October 17, 2018 Report Share Posted October 17, 2018 Are there weber with overflow return to tank? Quote Link to comment
datzenmike Posted October 18, 2018 Report Share Posted October 18, 2018 Don't know. It's easier to have a properly set fuel level. Some Hitachi SUs have over flow tubes that dump gas down beside the engine.... kind of scary if you ask me. Quote Link to comment
racerx Posted October 18, 2018 Report Share Posted October 18, 2018 Get a hold of pierce manifold, Gilroy, ca They may know. They sell real webers. Quote Link to comment
Stoffregen Motorsports Posted October 18, 2018 Report Share Posted October 18, 2018 All the Weber DGV carbs I have ever seen have two ports on the lid. one for inlet and the other plugged from the factory with a removable, threaded plug. I am sure they do this to give the option of which side of the carb you want your fuel inlet (fitment issues), but it could conceivably be used for a return setup with a regulator. Don't really think you would need one though on a low pressure system such as this. Why do you want a return line? Quote Link to comment
Draker Posted October 18, 2018 Report Share Posted October 18, 2018 I've seen some with a return line. It's not needed though. I assume you are asking because your 69 510 has a factory return line. I would just cap it off on both ends. That's what I did on mine. Quote Link to comment
