mamanee69 Posted September 19, 2018 Report Share Posted September 19, 2018 New owner and new member. Truck seems to be in fairly good shape. I'm looking forward to my first DIY project. Have noticed a couple hoses as well as what I thing would be air hoses that are missing or not attached. I'm hoping to find some diagrams to begin my comparison to. Any help would be appreciated.. 1 Quote Link to comment
Pacific coast Datsun Posted September 20, 2018 Report Share Posted September 20, 2018 www.infamousnissan.com may have some factory service manuals in the tech section. Or just Google search what you need. 1 Quote Link to comment
mikecaleb Posted October 1, 2018 Report Share Posted October 1, 2018 Im wanting to get rid of the big jumbled up mess of wires under the hood. i figured it'll be best to just start over from the battery. i know that the positive battery cable runs down to the starter. and i know where my negative cable hooks too. iIgot a 86 Nissan z24i wiring harness in the truck. (useless to me at this point). Im putting a z22 back into the truck. its got a weber, mechanical fuel pump and vacuum advance distributor so there's not many wires that's needed i don't believe. Ive already got a wire running from my start/run source on the ignition switch through a fuse(what size fuse would i need to use ) for the ignition system already spliced for the two positive coil terminals and i know that the two negative wires will come from the distributor to the negative side of the coils.So pretty well I'm needing to know the rest of the charging and starting wiring routes or if there's anything that im overlooking . also if anyone happens to know which wires behind the cluster are for the oil pressure switch and temperature sender that'd be great. Thanks in Advance Quote Link to comment
mikecaleb Posted October 2, 2018 Report Share Posted October 2, 2018 https://goo.gl/images/n5YSE5 This may help. Does the motor still have the TBI or has it been converted to a Weber Carburetor already? That will make all the difference in which ones are actually needed and which ones can be capped off. Quote Link to comment
datzenmike Posted October 2, 2018 Report Share Posted October 2, 2018 You already have a post on this truck. https://ratsun.net/topic/74440-1986-d21-w-zmotor-inspect-and-repair/?tab=comments#comment-1584794 Multiple posts lead to multiple and duplicate answers and much confusion. Not everyone will be on the same page. If you feel your original topic has changed you can go to your first post and change the title. I can also merge the other one with this one if you prefer? If putting a Z22 back into the truck did it have one in it before or are you saying that you are replacing the Z24i with a Z22????? The water temp sender (under the top rad hose on the intake) and the oil pressure sender (half way up side of block under the intake) on the Z24i and the Z22 are in the same place just connect the D21 harness up to it and the gauge will work. Quote Link to comment
mikecaleb Posted October 2, 2018 Report Share Posted October 2, 2018 yeah i was questioning whether i should keep it in the same thread or not lol. You can go ahead an combine them though .i appreciate it. And yes I'm replacing the z24i with the z22. I'm wanting to pretty well make my own engine wiring harness so i can get rid of the big pile of wires on the fender wells that not being used anymore. Quote Link to comment
datzenmike Posted October 2, 2018 Report Share Posted October 2, 2018 I wouldn't advise this. You have everything you need on this harness. Headlights/parking and side marker, charging system, all the fusible links, reverse lights from the transmission, start, oil and temp senders. Just cut off the sensor wires for the Z24i that are not needed. Somewhere on the throttle body is a switched 12 volt source that will power the choke heater and idle cut for the carb. Trim away unneeded wires and cover the rest with plastic split harness covering to neaten it up. Quote Link to comment
mikecaleb Posted October 2, 2018 Report Share Posted October 2, 2018 Oh ok i didn't know i could just clip them and cover them up. i figured it'd leave a bunch of open circuits or something and give me problems. That works for me though. I'll be able to get rid of quite a few in that case. Ive got a wire already ran for the choke and idle cutoff switch so that wont be an issue neither. Quote Link to comment
datzenmike Posted October 2, 2018 Report Share Posted October 2, 2018 An open circuit is no problem. Wires touching something they shouldn't is. Tape them up Quote Link to comment
mikecaleb Posted October 2, 2018 Report Share Posted October 2, 2018 Hell yeah. i know what Im doing tomorrow then as long as this rain holds out. Ive been wanting to get rid of that mess for a long time. You sir never fail to answer a question and steer me in the right direction. You should get paid for doing this stuff. Quote Link to comment
mikecaleb Posted October 26, 2018 Report Share Posted October 26, 2018 there are two wires that come out of the alternator. the green and yellow. im needing to know wich one is number 1 and wich is number 2. Quote Link to comment
datzenmike Posted October 27, 2018 Report Share Posted October 27, 2018 I can't find any Green or Yellow wires on my wiring diagram. Only White and White/Blue stripe. The ground is probably Black Quote Link to comment
mikecaleb Posted October 27, 2018 Report Share Posted October 27, 2018 That sucks. I figured out that the old harness was shot as alot of the wires were melted together between the firewall and computer. I have no idea what happened there. Ive always had crazy electrical issues with the truck. At one point my neighbors would tell me my lights in the front would come on randomly throughout the night and flicker.So im going to attempt to rewire the truck. i was thinking it would be be best strting with starting/charging section of wiring. This is a diagram that i am attempting to work with. the only part that stumps me is the two wires coming from the alternator and how to tell them apart. Also i was wanting your input mike on what do you think i should do in this situation? am i headed in the right direction? or should i invest in one of those universal wiring harness? Quote Link to comment
datzenmike Posted October 27, 2018 Report Share Posted October 27, 2018 Oh hell, I was assuming this was a 720. ? Can you find another Hardbody that had the Z24i and strip an engine harness out of it? Quote Link to comment
mikecaleb Posted October 27, 2018 Report Share Posted October 27, 2018 it might as well be at this point lol. And ill look around and see if i can find one. Quote Link to comment
mikecaleb Posted March 30, 2019 Report Share Posted March 30, 2019 alright so i have installed a painless performance chassis wiring harness. its turning over fine, getting fuel, but no spark at the distributor. there are 4 wires coming from the distributor. 2 of them are hooked to the negative side of the coils. 1 of them is spliced into the 12 volt ignition soure wire that feeds power to the coils. and the last white wire is left unhooked. Is there something that im missing? maybe a ground Quote Link to comment
datzenmike Posted March 30, 2019 Report Share Posted March 30, 2019 Distributor grounds through it's mount to the timing cover. Check the Red? (I think) power wire for 12 volts. Make sure there is power when using the starter motor. Leave the White wire disconnected. Quote Link to comment
mikecaleb Posted March 30, 2019 Report Share Posted March 30, 2019 That may be my problem. Ive got the red and blue wires to the negative side of the coils and the black to the 12 volt ignition source Quote Link to comment
