71dimeSR20 Posted September 21, 2018 Report Share Posted September 21, 2018 I’ve been looking for a while now, and cannot seem to locate a chassis harness for a 1971 Datsun 510 sedan with an s13 SR20DET motor... Any ideas as where to find an affordable and easy to install wiring harness is?? Any help would be great!! Thanks! Quote Link to comment
datzenmike Posted September 21, 2018 Report Share Posted September 21, 2018 There's no such thing. There are harnesses for the SR's ECU that controls the EFI. These usually come with the import engine and you have to 'graft' it onto the older 510's power and ground. I think there are some custom ones available on line. https://www.wiringspecialties.com/s14srwihafor1.html If you can find a stock SR harness Icehouse is a member here and sels the Can/Am box which makes the conversion much easier. http://www.the510realm.com/viewtopic.php?t=6589 1 Quote Link to comment
KoHeartsGPA Posted September 21, 2018 Report Share Posted September 21, 2018 Yeah, once you have the ECU and harness of an SR then get the can am box from Icehouse, it is very simple to wire up and a quick Google search or look for SR swap builds here to get the diagram Quote Link to comment
heywier427 Posted September 21, 2018 Report Share Posted September 21, 2018 (edited) This is the easiest solution: https://www.wiringspecialties.com/datsunsr20.html I did not do it in my 510 yet, but did it in my hardbody. Very simple. Make sure to choose the correct options for what you have. But like Mike says, a stock sr harness with the can am box does the same thing for less if you have some common sense. The wiring specialties is made to be installed while you are stoned and retarded (most 240sx kids). There are pretty pictures and it is all very well labeled. Great product for the millennials who want to weld there diff and drift bro. ? Edited September 21, 2018 by heywier427 Quote Link to comment
Jesse C. Posted September 21, 2018 Report Share Posted September 21, 2018 And for the rest of the car... https://www.ezwiring.com/ Quote Link to comment
