dukerollo 267 Report post Posted September 14, 2018 Does anyone know of this being done anywhere? Does anyone have any pictures? I’m sure I’m not breaking new ground. I have finally got the engine and trans in at the same time, but it has required major surgery. I still don’t know if the hood will go back on. I can can see why Nissan stretched the nose on the Sunny Perfects, there are no room in these damn things. When it’s not 3:30 in the morning, I’ll update my build thread. This little tangent of the project has been a bit more than I bargained for....or I’m just tired and being bitchy.... Share this post Link to post
Unfamilia 10 Report post Posted September 14, 2018 Hi, I've put an L16 in my round light 79 b310 (b210 in USA) Yes the hood hit just where the cross brace sits in the underneath the bonnet. I used shorter engine mounts to drop it 10mm. Good luck trying to fit a L20 with stock carby. I used twin su carbs. What major surgery did you do? I only had to fit the pa10 pedal box for a hydraulic clutch and some relief on the gearbox cross member to fit the 5speed gear box . Share this post Link to post
dukerollo 267 Report post Posted September 14, 2018 I moved the engine back because I couldn’t get the radiator in. Now the 280zx trans is too friendly with the tunnel, so I had to do some chopping. I am going to be using a KA head eventually which should give me hood clearance. Did you have room for a rad in the stock location, or did you modify the core support? If you have any pics I would love to see them. Share this post Link to post
Unfamilia 10 Report post Posted September 15, 2018 I used a SR20 radiator that had the inlets and outlets on the correct sides. It's a twin core. Takes up the whole nose cone area between the chassis rails Sent you a message about the pictures. Share this post Link to post
dukerollo 267 Report post Posted September 24, 2018 All sorts of radiator space now that I’ve done this Share this post Link to post
Unfamilia 10 Report post Posted September 24, 2018 That's one way to do it Share this post Link to post
afracer 31 Report post Posted September 26, 2018 If I were to start over, I would've just started with an A10 wagon instead of my B310 wagon. I didn't realize until afterwards that they're basically identical except a few trim pieces and the L20B and H165 vs A15 and H150. Oh well, I've always been a Sunny fan. Good luck with the swap, it can't be harder than an SR in a 1200! 1 Share this post Link to post
dukerollo 267 Report post Posted September 26, 2018 (edited) I actually had an A10 wagon. That is where this engine come from. That car is still running around with the A15 from the Sunny in it. I was also also under the impression that they were near identical cars until I started down this rabbit hole. The A10 is slightly larger in some key dimensions and accommodates the much larger L20 easily. The Sunny is a bit lighter and easier to get parts for over here, so I have no regrets. Plus projects like this keep me off of the street corner. Lol. Thanks for the well wishes. Edited September 26, 2018 by dukerollo 1 1 Share this post Link to post
Unfamilia 10 Report post Posted September 27, 2018 It's not identical the a10 and b310 chassis. Only the engine cross member lines up. Even the firewall where the pedal box mounts is different. Small differences in key areas as discussed but yes it's a nicer package than the a10 one. Share this post Link to post
