L16 SU carbs?
Roc1479
  • Replies 5
Four bolt Roadster carbs on an L series intake. I think they are 40mm? Should work alright although the L16/18 SSS used a 38mm SU.
Maybe 240z carbs which would be 46mm? and a little large for the L16 but still work.
They will work on a stock L16 but were used on the JDM L16SSS Coupe which had different pistons and cam. If you want the same cam as the L16SSS find an L20B cam.
$150 is a great price. You'll need choke cables and connect up the throttle linkage. They are a lot of work to get running just right but then they run forever and are very reliable.
  • 3 weeks later...
Rocky?  The pic links don't work for me, but if the dual carb set is the SSS 2 bolt mounting, I have an NOS linkage kit for it!  PM or email me if interested!
Also, the British sports car Triumph TR6 dual choke cable is a good set up........OEM part # UKC2121..........source online at Moss Motors or Victoria British.
TJ
Denver CO
