JonnyW Posted September 10, 2018 Report Share Posted September 10, 2018 Hi. I've searched around on Ratsun and haven't been able to find a previous post with an answer so I hope that someone here can help. I have a 1978 620 with a 4 speed column shift and the linkage bushings are shot. Can someone help out with a part number or a link to a part that would fit? I've counted 6 in total that need replacing so I'm assuming the bushings would be identical for all. I took the most accessible one apart and it looks like someone has used plastic tube and shimmed it with some washers. The rest look like worn rubber bushes and a couple are missing completely. I've found this which claims to be a column shift link bush (part 34552-h1010) but I'm not sure if it is the correct part. http://www.nzdatsunparts.co.nz/search/datsun-column-change-gear-shift-linkage-bush?gn=Search%20Results&gp=6 Thanks. Jon 1 Quote Link to comment
]2eDeYe Posted September 10, 2018 Report Share Posted September 10, 2018 Looks like there are a number of bushings in that bag. Being your at least in the same country, you should contact NZ Datsun Parts directly. 1 Quote Link to comment
