Cardinal Grammeter Posted September 4, 2018 Report Share Posted September 4, 2018 (edited) AutoZone vs NAPA is what it boils down to. I would think Echlin is better than Duralast, but I know nothing about LockSmart. For my 1974 610. EDIT: OOPS TYPO! I have a 620 BTW AZ is Lifetime, NAPA is 3yrs. Maybe get the LockSmart for the warranty??? Edited September 7, 2018 by Cardinal Grammeter 1 Quote Link to comment
banzai510(hainz) Posted September 5, 2018 Report Share Posted September 5, 2018 (edited) Rock auto had soem Beck Arnley marked switches for the 521 and It looked like stock Japanese Echlin Mechanical Volt regs for the Datsun are junk and dont buy them Edited September 5, 2018 by banzai510(hainz) 1 Quote Link to comment
Rick-rat Posted September 6, 2018 Report Share Posted September 6, 2018 Post some pics of your 610 1 Quote Link to comment
Cardinal Grammeter Posted September 7, 2018 Author Report Share Posted September 7, 2018 (edited) Oops, typo: I have a 620, not a 610. I bot the AZ Locksmart. I'm going to try and swap the cylinder. If it won't swap, I'll probably take it back. RATS, no way to remove cylinder at all. Looking at other make switches and the Standard looks like it has the recess for the removal pin, but there is no actual hole. I wonder if I can buy a switch where I can use my old cylinder???? (Possibly Beck-Arnley - mechanic friend who is also locksmith says B-A switch cylinder comes out.) Edited September 7, 2018 by Cardinal Grammeter 1 Quote Link to comment
Charlie69 Posted September 8, 2018 Report Share Posted September 8, 2018 I have run the Beck Arnley switches in 521s, 620s and currently in my 720 daily driver. I have had no bad experiences with the beck Arnley switches. I have also used the Airtex/Wells switches and have had good luck with them also. https://www.rockauto.com/en/catalog/nissan,1974,620+pickup,1.8l+l4,1210105,electrical-switch+&+relay,ignition+starter+switch,4700 Quote Link to comment
Cardinal Grammeter Posted September 9, 2018 Author Report Share Posted September 9, 2018 The Beck switch cylinder will not interchange with the OE. I would not use the LockSmart. The spade connectors on the back feel thinner (bend easier) than the OE. I recreated the engine shutting off due to ignition switch today. It is weird in that it seems to only occur when I'm winding out the gears well into the secondary. This time I was ready for it and was giggling the switch a second after it happened. And yes, it was the switch. Don't know why only with winding out gears... I going to try a used OE from car-part.com. I just don't want to have two sets of keys which is ghetto in my book. Yes, I know. I'm being OCD. Quote Link to comment
Cardinal Grammeter Posted October 11, 2018 Author Report Share Posted October 11, 2018 Bot a $15 + 15 shipping used from car-part. Works fine and the cylinders swapped. (I figured even if I got a bad one, I'd just buy another until I got a good one.) Quote Link to comment
