720 King Cab Killer Posted September 3, 2018 Report Share Posted September 3, 2018 I have two wires that Im sure supply's power to the AC compressors. Turned the key on pulled out the little AC switch in the cab controls and the blue light cam on that says AC. I'm not getting any power to the two wires. Even with the car running I found no power before I took off the carb..... One of them has got to be the power for the ac compressor gotta be. I did a continuity test and got 1 so Im thinking a break some place? Is their a AC relay somewhere I cant find it. Nothing on my fuse box says anything like AC fuse or relay. I don't get it I'm doing something wrong why cant I find power from one of them wires? Before I took the compressor out it did work I got the clutch to spin going direct form the battery just to see if it worked....Im sending it off to Florida tomorrow to be rebuilt...lol yea Florida. MAN I hope its not somewhere in my wiring harness...…………. Any ideas? 1 Quote Link to comment
Charlie69 Posted September 4, 2018 Report Share Posted September 4, 2018 The wire comes off that switch you pull out and it goes out to the switch on the accumulator dryer from that switch one wire usually the black with red stripe goes out to the compressor. I hope this helps. Quote Link to comment
720 King Cab Killer Posted October 16, 2018 Author Report Share Posted October 16, 2018 Well Thank you but The AC is on hold for awhile I GOT RIPPED OFF my compressor is gone gone. I found a place called Jensen Auto in Michigan they said ship it out they will rebuild it ( cost 50 bucks) and ship it back. Well they said they never got it. TOTAL BS Fed Ex dropped it off there at 11:49am Sep 12. SO I got ripped off...Fuck them guys! AND I'm not the only one there are some shitty reviews about them fuck heads. SO I just ordered a new weber carb/adapter plate and gonna go with that. My question now is what kind of compressor do you all think will fit my motor? The only thing I saw the even looks like it will fit is a 1981 Kamastu excavator ac compressor it looks very very close same compressor just about.... 1 Quote Link to comment
Charlie69 Posted October 16, 2018 Report Share Posted October 16, 2018 What year truck is it ? Did you take the mounting bracket off before shipping it out to the ripoff artists? Quote Link to comment
720_Jeff Posted October 16, 2018 Report Share Posted October 16, 2018 There are plenty on eBay. Looks like they start @ $145 for a reman 1 Quote Link to comment
thisismatt Posted October 16, 2018 Report Share Posted October 16, 2018 As the diagram shows, the compressor won't see power if the low-pressure switch is engaged, which it would be if your refrigerant was low or non-existent. 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 Yes I did keep my AC bracket...so YES on that. ALSO my weber came in the mail just one question witch way does the adapter plate go on? I think its the top picture way is correct. Charlie 69 you have done them before so what is it? 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 I can see there is gonna be some excess gasket inside can I trim it flush with a razor blade? 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 47 minutes ago, 720 King Cab Killer said: This way? Quote Link to comment
Charlie69 Posted October 19, 2018 Report Share Posted October 19, 2018 Yes on the razor blade. Is that a 2 piece adapter? All my adapter looks Like this one on my 86 720 King cab. Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 For some reason they sent me two different ones...I got one just like yours and the other one in the pic.... 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 Nope take that back I got two sets like the ones in the pics.... 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 1981 720 king cab I got the 22 motor... 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 I'm confused now what the fuck.... ? I got part 99004.333 adapter plate and carb....Shit hope I got the right shit from pierce.... 1 Quote Link to comment
Charlie69 Posted October 19, 2018 Report Share Posted October 19, 2018 That is the carb kit listed for the 81-82 Z22 engine. That is correct. The z22 has a different adapter than the z20 or the Z24 engines. If you want PM me and I can come to your place on Sunday and help you install your Weber. Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 I'm gonna need that throttle cable holder too just like this in the pic.......The factory one I have is WAY to tall and will not fit. You got a extra one? 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 So here's my "fabrication" on my throttle cable bracket lol more like bending but it works and is free and clear 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 The return spring sure does make my floor pedal feel good not to tight not too loose. 1 Quote Link to comment
720 King Cab Killer Posted October 19, 2018 Author Report Share Posted October 19, 2018 Missing parts??? or do I cap them off??? 1 Quote Link to comment
Charlie69 Posted October 21, 2018 Report Share Posted October 21, 2018 Where did you buy your carb? That looks like an EMPI knock off, not a Weber. Quote Link to comment
720 King Cab Killer Posted October 22, 2018 Author Report Share Posted October 22, 2018 LOL On pierce manifolds web page. I think it might look different cause its for a 1981 Z22 part number K663-38. Why does it look like a knock off? 1 Quote Link to comment
720 King Cab Killer Posted October 22, 2018 Author Report Share Posted October 22, 2018 MAN...I think its a 38/38 DGES I thought I got a 32/36 part K663-38 after looking at some pics on line yep its a 38/38........... the price is about right that I paid. LOL No wonder the truck hauls ass now and I can chirp the tires in first gear! I gotta check my Credit card...But yea I'm sure that's what I got. OH WELL it is way faster now lol....gonna pay for fuel now ? 1 Quote Link to comment
