sidebeub Posted August 22, 2018 Report Share Posted August 22, 2018 So I put a weber on my little truck and its running ok, but have a few fine tuning questions. It stumbles a bit at low rpm and idle is low when its cold. Once shes warmed up idle is good, stumble is still there but not as noticeable. She does diesel a bit when hot during shut off. I'm thinking its timing related. My Haynes book shows 12-15 BTDC, but I see others commenting it should be around 5-7 BTDC. I don't have the stamp under my hood to tell me factory settings. Does anyone know what factory settings would be my truck is a 1984 2wd 2.0. I'm using a timing light, disconnecting the distributor vacuum line and plugging the distributors hole when checking. (not sure if you plug the vac line or dist. hole) its around 7 now. At 12-15 she runs good, but really struggles to idle when cold. I turn up idle, but once we're warmed up idle is too high. Appreciate the help! Love these little trucks! 1 Quote Link to comment
datzenmike Posted August 22, 2018 Report Share Posted August 22, 2018 I have that at home but may be the same as the Z24 which is 3 +/- 2 degrees. Definitely not 12 degrees. Won't hurt to disconnect the vacuum advance but this is a hold over from the 50's and into the '60 when vacuum advance was taken from the intake. Now it's from a port on the side of the carb above the throttle plate, so there should be none at idle if everything is set right. I would confirm that both intake and exhaust side plugs are firing. The choke probably needs to be set richer than it is. 1 Quote Link to comment
sidebeub Posted August 22, 2018 Author Report Share Posted August 22, 2018 Thanks Mike! I know the compression was higher in the z20 so wasnt 100% sure what info to base off of. The choke crossed my mind as well ill tweak it. Plugs are new, wires about 5 years old I'll confirm spark all round though. I'll try 3 +/-2 degrees, have a broken distributor bolt to deal with now ? LoL 1 Quote Link to comment
datzenmike Posted August 22, 2018 Report Share Posted August 22, 2018 OK the Z20 is 5 degrees +/- 2 degrees. Don't forget the Z20 has a knock sensor and ignition retard so stick to the 5 degrees. 1 Quote Link to comment
sidebeub Posted August 27, 2018 Author Report Share Posted August 27, 2018 Timing is set at 5 now thanks again Mike! So for adjusting the choke, do I just move the coil inside the housing or is there a fast idle screw I'm missing? Found a write up on the forums already so I'll try to tweak my choke. Quote Link to comment
datzenmike Posted August 27, 2018 Report Share Posted August 27, 2018 Some years the choke is factory set and rivetted so it can't be messed with. If you can adjust set it on a cold engine. Turn till the flap closes. This should get you started. Quote Link to comment
