720 King Cab Killer Posted August 18, 2018 Report Share Posted August 18, 2018 So My clock aint working on my 720. Do I gotta take the whole cluster out to test it? I know gotta make sure I got power to the clock I know about the white/blue plug that connects the cluster looked at some old posts and about my Tac....Gotta get one of them relay resistor little plugs cause my tack quit working too...Any test to do that I don't know about? .... 1 Quote Link to comment
MaxChlan Posted August 18, 2018 Report Share Posted August 18, 2018 (edited) Check location 8 on the fuse block; should be 10A fuse that goes to the clock, inspection lamp, and the horn. You may be able to access the plug for the clock from under the dash by removing the black metal under-dash cover. Here is the wiring diagram for the clock to check for power: Edited August 18, 2018 by MaxChlan 1 Quote Link to comment
datzenmike Posted August 19, 2018 Report Share Posted August 19, 2018 Why are you replacing the tach resistor? Don't you think that the clock and the tach not working is connected somehow? 1 Quote Link to comment
Charlie69 Posted August 20, 2018 Report Share Posted August 20, 2018 Did either ever work since you have owned the truck? Quote Link to comment
720 King Cab Killer Posted August 25, 2018 Author Report Share Posted August 25, 2018 No the tack worked fine tell a few weeks ago its week and flops around kind of I was thinking it was that resistor thing....Where can I find one? 1 Quote Link to comment
720 King Cab Killer Posted August 25, 2018 Author Report Share Posted August 25, 2018 The clock never worked its got a weird plug...no green wire anywhere for power just a white plug with a green wire/brown and it goes to the side somewhere all crammed in there 1 Quote Link to comment
datzenmike Posted August 25, 2018 Report Share Posted August 25, 2018 23 minutes ago, 720 King Cab Killer said: No the tack worked fine tell a few weeks ago its week and flops around kind of I was thinking it was that resistor thing....Where can I find one? Get a meter and test it. 2.2K or 22,000 ohms. Gets expensive throwing parts at it. Nissan # 24280 N8200 The 280zx, 300zx, S110 200sx, S12 200sx, Maxima, S12 200sx, Sentra, Stanza Pulsar NX.... all used it. Quote Link to comment
720 King Cab Killer Posted August 25, 2018 Author Report Share Posted August 25, 2018 Ok So auto zone will have it? Nissan # 24280 N8200 The 280zx, 300zx, S110 200sx, S12 200sx, Maxima, S12 200sx, Sentra, Stanza Pulsar NX under all these models? 1 Quote Link to comment
datzenmike Posted August 25, 2018 Report Share Posted August 25, 2018 No idea, Nissan might. It's under $10, and your time and gas. Check it first. 1 Quote Link to comment
Charlie69 Posted August 29, 2018 Report Share Posted August 29, 2018 The tac resistor is a discontinued part. Quote Link to comment
