Air flow problem
Elivandal89
  • Replies 3
That is called dieseling and all you have to do is let out the clutch when shutting off the motor.  Is this a stock carb or is it throttle body injection.  The easiest way to tell is
does the air cleaner have 1 wing nut or 2?  1 is carbureted and 2 is throttle body injection.
It shouldn't do this. It means gas and air are still getting into the engine after being turned off. If a carb engine, the idle cut solenoid shuts off fuel to the idle circuit. Not sure about the throttle body injection... probably the injectors are shut off but if leaking (dripping) it would diesel as fuel pressure does not immediately stop..
