Eriks Posted August 12, 2018 Report Share Posted August 12, 2018 Hi, I need to replace the old front shocks. Any advice what shocks to buy? E.g.is it correct that you can use KYB 365013 with a spacer? If yes, how long should the spacer be? Thanks ? Quote Link to comment
datzenmike Posted August 13, 2018 Report Share Posted August 13, 2018 If you have the original oil bath dampers empty the thin watery hydraulic fluid and replace with thicker viscosity motorcycle fork oil. I did my Maxima struts this way using Bell Ray 20W fork oil. This keeps the original compression/rebound design and just stiffens/renews the action. $20 CDN for a liter that will do three struts. As to the inserts, they must be the same length or shorter than the originals. Just add washers under the insert to make up the difference and bring it up snug to the gland nut when tightened down. Quote Link to comment
Humboldt Posted August 13, 2018 Report Share Posted August 13, 2018 Sorry for dumb ? but can you do this without removing the strut? Quote Link to comment
datzenmike Posted August 13, 2018 Report Share Posted August 13, 2018 No. It has to come out and remove the coil spring. But you would have to remove it to put inserts in anyway. 2 Quote Link to comment
Eriks Posted August 13, 2018 Author Report Share Posted August 13, 2018 (edited) Thanks for the advice. No, the original shocks are gone. A workshop replaced them with the KYBs. Now there is a clunking sound on both sides, guessing they did not use spacers. Now I’ll try to the job myself, with the assistance of ratsun and youtube. Edited August 13, 2018 by Eriks Quote Link to comment
datzenmike Posted August 13, 2018 Report Share Posted August 13, 2018 Sounds like this is the problem. Washers seen the cheapest easiest. Quote Link to comment
Eriks Posted August 13, 2018 Author Report Share Posted August 13, 2018 Yes, that was it. 15mm play. Tomorrow morning l’ll buy a handfull of washers. Thanks again Datzenmike ? Quote Link to comment
