FiremarshalBill49 Posted August 5, 2018 Report Share Posted August 5, 2018 What is it inside my doors that would cause/allow the windows to rattle when rolled down? The windows don't "seem" lose and the inner and outer window seals at the bottom of the window openings have recently been replaced (cheap Thai replacement parts - don't get me started), but there is a persistent window rattle inside the doors, especially when rolled down. I haven't taken the door panels off yet for a look-see and was wondering if there are some parts I should order before jumping into a fix. 1 Quote Link to comment
thisismatt Posted August 5, 2018 Report Share Posted August 5, 2018 If you haven't taken off the door cards, then you haven't replaced the window channel felt I assume...that would be it 1 Quote Link to comment
Seeker > 620 KC Posted August 5, 2018 Report Share Posted August 5, 2018 could also be the linkage bar that clips into a plastic retainer or you might a nut that fell off, or you might find two 1979 pennies rattling around like I did. but i’m with on this, take it apart and see what it is before you guess and blindly buy parts, it won’t keep you from driving it if the door panel is off 1 Quote Link to comment
datzenmike Posted August 5, 2018 Report Share Posted August 5, 2018 Have someone hold the glass to be sure it's the glass. If it is, it's likely the felt in the vertical window guides that are out of sight in the door. To be sure take the door card off and shake the door and look for it. 1 Quote Link to comment
