Rasp933 Posted August 4, 2018 Report Share Posted August 4, 2018 (edited) What's up fellas. I am currently running 280zx front inserts.On my 70 510,and it keeps bottoming out .any ideas ,which inserts will give better riding experience s.thanks Edited August 4, 2018 by Rasp933 Quote Link to comment
datzenmike Posted August 4, 2018 Report Share Posted August 4, 2018 ZX inserts in stock 510 struts??? They are too short... did you stack washers under them? to make up the difference?? Bottoming out is from being too low and/or too soft a spring. What springs? Quote Link to comment
Rasp933 Posted August 4, 2018 Author Report Share Posted August 4, 2018 zx inserts in zx struts.with coilover s Quote Link to comment
datzenmike Posted August 4, 2018 Report Share Posted August 4, 2018 If there was a space under the insert did you stack washers under it? Most inserts are generic (one size fits others) and are a tad short. Bottoming out? This leaves too low and/or too soft a spring. Or the inserts are crap. The stock 510 coil is around 90 lb/in which is fine at stock height but if lowering you risk hitting things so it's advised to increase the spring rate. Lower = stiffer. I think most 510s that are lowered are in the 200 lb/in and over and in extreme cases 300. What about the rear? How did you lower it. What springs did you swap in. Quote Link to comment
banzai510(hainz) Posted August 4, 2018 Report Share Posted August 4, 2018 I really dont think your bottoming out. If you have coil overs one can adjust to raisse the lower collar spring seat. most coil over have at least a 180 spring in there that I have seen. Might have less travel if ones uses a 7in spring as most are 8in. I just dont drive on rought roads and hit steel plates at road cnstruction sites at over 35mph Quote Link to comment
