oukippy Posted August 2, 2018 Report Share Posted August 2, 2018 Hello, Does anyone know if this kind of led headlights will be compatible with a 620 ? https://fr.aliexpress.com/item/Pour-Harley-Davidson-Street-750-Led-Phare-5-3-4-harley-lampe-led-moto-phare-DRL/32840689288.html Thank you! oukippy Quote Link to comment
nl320what Posted August 2, 2018 Report Share Posted August 2, 2018 H5001/H5006 are the sealed beam original models, so you would want to search those for led equivalents like HERE for example. 2 Quote Link to comment
datzenmike Posted August 2, 2018 Report Share Posted August 2, 2018 Datsuns use 5 3/4" lamps, these are only 5.5" wide. I'm sure there are 5 3/4" available. Also do these have a cut a off projector beam??? There nothing like blinding and pissing off oncoming traffic and bike headlamps do this, but I accept that they are at a disadvantage at night. Cars have no excuse for annoying others. High beams you can run full beam. If driving around town or at lower speeds you don't need to see shit 5 blocks away. 2 Quote Link to comment
Trochu Posted August 2, 2018 Report Share Posted August 2, 2018 I've wondered what it would look like to have a white background bulb on the outside and then a black background bulb on the inside. Might have to try it one of these days. Quote Link to comment
oukippy Posted August 3, 2018 Author Report Share Posted August 3, 2018 I'm just giving a look at it but I'm not sure I will buy them. I don't have the car for now and I will probably have more important tasks to do. Maybe one day. Leds are interesting because it's plug & play. But I agree that you have to respect the oncoming drivers. I wonder if it's possible to find authorized models (probably not on aliexpress for sure). 1 Quote Link to comment
datzenmike Posted August 3, 2018 Report Share Posted August 3, 2018 I looked at LED a few years ago but all made outrageous claims for light output. Seems you would need to spend $300-$400 for state of the LED art at the time. There are oodles of You Tubes where LEDs are substituted and... they look just as bright as the original halogen ones. I went with projector HID. It's like driving with an arc welder in front and a nice crisp cut off line.. 1 Quote Link to comment
banzai510(hainz) Posted August 3, 2018 Report Share Posted August 3, 2018 Delta makes Lights also in 5.75 1 Quote Link to comment
78kingcab Posted August 4, 2018 Report Share Posted August 4, 2018 If I was gonna go with leds I'd by housings then led bulbs.. seems stupid to me to by ones you can't change the bulb.. I went with halo hids 1 Quote Link to comment
oukippy Posted August 5, 2018 Author Report Share Posted August 5, 2018 9 hours ago, 78kingcab said: If I was gonna go with leds I'd by housings then led bulbs.. seems stupid to me to by ones you can't change the bulb.. I went with halo hids Could you show me which halo HID you have ? Is a conversion kit needed with HID ? Quote Link to comment
G-Duax Posted August 5, 2018 Report Share Posted August 5, 2018 I hate HIDs, with their jittering elements. I just installed my first pair of Hella conversion housings, and PIAA LEDs. Couldn't be happier with the results. I had eCheesy conversion housings, with H4 standard bulbs, and couldn't see shitz. Plus the El-Cheapo conversion housings chipped easily. Guess the chinese have no idea how to make good glass...Just like people are finding out on 620 windshields. Quote Link to comment
datzenmike Posted August 5, 2018 Report Share Posted August 5, 2018 The jitteryness is just the projector beam cut off point moving up and down from vehicle movement over the pavement. If aimed horizontal it will be at or near the tops of your tires as you approach and you are sitting well above it in darkness. Naturally roads are not level so sometimes you do get flashed. Quote Link to comment
oukippy Posted August 5, 2018 Author Report Share Posted August 5, 2018 I'll give a chance to the stock ones for some time and will reconsider changing them after the trial. I don't plan to drive very much at night, so it's more a cosmetic search for me. The truck is now in Europe but I'll have to wait at least 15 days to have it home. I'm loosing patience so I look everywhere for things to improve (and buy). Of course I should wait to see the truck for real, especially for the mechanical part !? 1 Quote Link to comment
FrankRizzo Posted August 6, 2018 Report Share Posted August 6, 2018 FWIW I installed Hella halogen H1/H4 retrofits a year ago, then recently swapped the bulbs to LED's from Amazon. They work great. Im all LED now. . Quote Link to comment
datzenmike Posted August 6, 2018 Report Share Posted August 6, 2018 Are they brighter? Quote Link to comment
oukippy Posted August 6, 2018 Author Report Share Posted August 6, 2018 3 hours ago, FrankRizzo said: FWIW I installed Hella halogen H1/H4 retrofits a year ago, then recently swapped the bulbs to LED's from Amazon. They work great. Im all LED now. . could you post the URL on Amazon? Quote Link to comment
Ron1200 Posted August 6, 2018 Report Share Posted August 6, 2018 Like this? https://ratsun.net/topic/35291-ron1200s-79-kc-620/?do=findComment&comment=1440054 I used these from Amazon $39.99 each. They worked better than the Sylvania sealed beam halogens I had in there. No wiring upgrades needed. Quote Link to comment
FrankRizzo Posted August 6, 2018 Report Share Posted August 6, 2018 (edited) 5 hours ago, oukippy said: could you post the URL on Amazon? https://www.amazon.com/gp/product/B077LJDCCP/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/LASFIT-Headlight-Conversion-headlight-Replacement/dp/B01EYQ8688/ref=sr_1_3?ie=UTF8&qid=1533558490&sr=8-3&keywords=lasfit+h4 LEDs are on the right and the halogen are on the left. The biggest benefit (besides better light) was less power draw. You would still have to purchase the Hella E-Code lights, so.... this is not the cheap way to do it, but it works great. http://www.rallylights.com/h5006-hella-5-3-4-round-e-code-hi-lo-conversion-headlamp-kit.html http://www.rallylights.com/h5001-hella-5-3-4-dia-h1-e-code-conversion-high-beam-headlamp-kit.html .... Edited August 6, 2018 by FrankRizzo Quote Link to comment
oukippy Posted August 6, 2018 Author Report Share Posted August 6, 2018 (edited) Yes, it's a big budget indeed. I will consider it in a second time, depending on how much I'll have to spend for the mechanics. For now, I'm just playing with Photoshop, no cheaper way ! Edited August 6, 2018 by oukippy Quote Link to comment
5t341tH Posted August 7, 2018 Report Share Posted August 7, 2018 I have these led headlights. They work good. It does have a large, square hotspot when driving down the road, but it's brighter than when i was using the bmw ellipsoids Quote Link to comment
oukippy Posted August 7, 2018 Author Report Share Posted August 7, 2018 5 hours ago, 5t341tH said: I have these led headlights. They work good. It does have a large, square hotspot when driving down the road, but it's brighter than when i was using the bmw ellipsoids are you talking about the Aliexpress ones in the first post ? Quote Link to comment
5t341tH Posted August 7, 2018 Report Share Posted August 7, 2018 (edited) Yea but mine doesn’t have those two smaller circle lights. I’ll snap a picture later. But I’ll ecentually retrofit a set of morimoto projectors into another set of lights. I am spoiled now by modern projectors and can’t drive around with nothing less Edited August 7, 2018 by 5t341tH Quote Link to comment
78kingcab Posted August 8, 2018 Report Share Posted August 8, 2018 I guess you get what you pay for... I bought dot approved glass housing that have a blue halo.. I inspected them and they are of very good quality... I then bought a quality hid kit and have absolutely no problems... excellent lighting... it is possible to get shit when you are cheap... like anything... not here to argue about lights.. lol... just stating that I wouldn't buy a set of lights that are sealed and you can't change the bulbs... there is nothing wrong with leds in anyway, but i feel the same for hids. Like i said you get what you pay for.. sorry havent figured out how to put pics or links up at yhis time... Quote Link to comment
oukippy Posted March 18, 2019 Author Report Share Posted March 18, 2019 I'm thinking about putting halo headlights like these ones : LED headlights Halo 5.75 I suppose that the red wire is for the halo ring. Should it be connected to the parking lamps ? Quote Link to comment
banzai510(hainz) Posted March 19, 2019 Report Share Posted March 19, 2019 Cibie H4s. they look weird and made in China I bet Quote Link to comment
Pauly7285 Posted March 22, 2019 Report Share Posted March 22, 2019 I bought and installed LEDs and couldn't be happier. They have a nice cut off and decent high beam. https://photos.app.goo.gl/vLhiQoBRDQ9h7qw17 Bought these. https://www.amazon.com/Projector-Headlight-Davidson-Motorcycles-Headlamp/dp/B019ETNZD6/ref=mp_s_a_1_5?crid=33XMSEHYOUM65&keywords=5.75+led+headlight+motorcycle&qid=1553271845&s=gateway&sprefix=5.75+led&sr=8-5 Quote Link to comment
