EDM620 Posted September 5, 2020 Report Share Posted September 5, 2020 Good to have friends who can help out... 1 Quote Link to comment
Ben_upde Posted September 5, 2020 Author Report Share Posted September 5, 2020 12 hours ago, EDM620 said: Good to have friends who can help out... Too true. Transmission is quieter than it has ever been. Makes me wonder how long that bearing has been ‘going out’ 🧐 Quote Link to comment
Ben_upde Posted September 16, 2020 Author Report Share Posted September 16, 2020 Been super smokey with all the fires everywhere so really haven’t driven her. I did get a third member out of a you-pull-it yard for a Ford 9” for $85. 54” wide axle housing and shafts are on order from speedway courtesy of some wheeling and dealing with the boss on a couple of his personal rigs that needed some attention. helped a coworker get a couple generators up and running for his homestead in exchange for a gear set, so that’s on order as well 😬 Looks like ill be having some fun setting the 3 link up again properly with a 9” sooner rather than later 😃 1 Quote Link to comment
Ben_upde Posted September 18, 2020 Author Report Share Posted September 18, 2020 2 Quote Link to comment
EDM620 Posted September 22, 2020 Report Share Posted September 22, 2020 That green really pops! 1 Quote Link to comment
Stoffregen Motorsports Posted September 22, 2020 Report Share Posted September 22, 2020 6 lug with a 9 inch? Must be custom. 1 Quote Link to comment
Ben_upde Posted September 22, 2020 Author Report Share Posted September 22, 2020 13 minutes ago, Stoffregen Motorsports said: 6 lug with a 9 inch? Must be custom. Had planned to be but turns out the only company that makes a high pinion 9” third member also makes their own custom gears for it At the price of $1600 for a third member they can keep it. I’ll redo the exhaust and do something different in the future. A Toyota 8” has a dropout third member, can be geared where I need to be, has an LSD available and is significantly cheaper. for now i’ve canceled the orders for the custom width housing/shafts with 6 lug pattern. 1 Quote Link to comment
Stoffregen Motorsports Posted September 23, 2020 Report Share Posted September 23, 2020 Toyota FJ80 front diffs are high pinion and will bolt into any 8" Toyota axle housing. I assume you knew that. They even came with an electric locker. That would be cool for track use. 2 Quote Link to comment
Ben_upde Posted September 23, 2020 Author Report Share Posted September 23, 2020 4 hours ago, Stoffregen Motorsports said: Toyota FJ80 front diffs are high pinion and will bolt into any 8" Toyota axle housing. I assume you knew that. They even came with an electric locker. That would be cool for track use. I haven’t had a chance to dig into other axle options and what will work with what yet. For now i’ll reconfigure what I have and just try to be relatively easy on it while focusing on bodywork and interior. Thanks for the info though! I’ll add it to my ‘look in to later’ pile Quote Link to comment
frankendat Posted September 23, 2020 Report Share Posted September 23, 2020 More for your later pile : I have a mostly complete set of FJ40 centers in 4:11. One that hasn't been touched since it was removed, the other I disassembled to make it work in another project. It didn't work and I put the parts in a milk crate in the garage. All the parts should be there, but I haven't gone through it years. I'm in Boise. 1 Quote Link to comment
Ben_upde Posted September 25, 2020 Author Report Share Posted September 25, 2020 Finally got around to replacing my pretty hacked steering wheel hub and quick release. Went legit this time all proper like to go with the Nardi wheel. slowly plugging away at the ugly and not quite tight parts 3 Quote Link to comment
Ben_upde Posted September 26, 2020 Author Report Share Posted September 26, 2020 Forgot to mention I placed an order with Speedhut a couple weeks ago 😬 should be here in a couple more weeks then i’ll have a working speedo, tach AND coolant temp gauge. Plus my fuel gauge won’t read inverse because a 10-90ohm sender was not readily available for my fuel cell 🤣 3 Quote Link to comment
Crashtd420 Posted September 26, 2020 Report Share Posted September 26, 2020 I love the look of the combo gauge.... Sweet purchase ... 1 Quote Link to comment
Stoffregen Motorsports Posted September 28, 2020 Report Share Posted September 28, 2020 If you can find a sending unit with the same sweep direction and in a similar range, you can install a resistor to get it close if not dead on. I use a volume knob from a guitar amp to figure out what resistance works, then get the proper resistor and solder it in line. 2 Quote Link to comment
5t341tH Posted September 29, 2020 Report Share Posted September 29, 2020 I wish the volts was replaced with oil temp on that gauge. I'd get it in a heartbeat 1 Quote Link to comment
Ben_upde Posted September 29, 2020 Author Report Share Posted September 29, 2020 1 hour ago, 5t341tH said: I wish the volts was replaced with oil temp on that gauge. I'd get it in a heartbeat If you call them, I believe you can get the gauges fully customized and they should be able to put a temp gauge in place of anything you’d like. Quote Link to comment
Ben_upde Posted September 29, 2020 Author Report Share Posted September 29, 2020 11 hours ago, Stoffregen Motorsports said: If you can find a sending unit with the same sweep direction and in a similar range, you can install a resistor to get it close if not dead on. I use a volume knob from a guitar amp to figure out what resistance works, then get the proper resistor and solder it in line. I’ve not used to potentiometer method, but have used inline resistors to take up the ‘remaining resistance’ from a sensor that is too ‘broad’ for the gauge. Luckily most new gauges can either be changed or ordered for the sender option you have or desire to run. It seems most oems are going to a single standard lately anyway. 1 Quote Link to comment
Ben_upde Posted September 29, 2020 Author Report Share Posted September 29, 2020 On 9/26/2020 at 5:24 PM, Crashtd420 said: I love the look of the combo gauge.... Sweet purchase ... Definitely what made me decide to go this route. I didn’t feel like cutting into the radio delete panel, or making a new one to put small gauges into. my boost gauge can just go into the top of the center console if i decide to run it full time. Probably won’t tho. Quote Link to comment
FrankRizzo Posted September 30, 2020 Report Share Posted September 30, 2020 ^ You're welcome! . Quote Link to comment
Ben_upde Posted October 1, 2020 Author Report Share Posted October 1, 2020 11 hours ago, FrankRizzo said: ^ You're welcome! . I think i’m missing something 🤔 Quote Link to comment
Ben_upde Posted October 3, 2020 Author Report Share Posted October 3, 2020 should be able to see a bit now that the days are getting shorter 🧐 1 Quote Link to comment
Ben_upde Posted October 4, 2020 Author Report Share Posted October 4, 2020 Night and day difference in light output 😳 Low beams High beams Super happy with the upgrade! I’ll likely upgrade the power circuit with some relays soon for maximum life 1 Quote Link to comment
Ben_upde Posted October 7, 2020 Author Report Share Posted October 7, 2020 Gauges arrived and are installed! I used an extra gauge cluster setup from a junkyard truck so as to not hack the fully functional set from my truck, not sure why though 🧐 bit of glare here but🤷🏼♂️ Everything working as it should overall super super happy with the set and the quality. Highly recommend speedhut if you’re after gauges. Not cheap, but then again what gauges are anymore? 1 1 Quote Link to comment
FrankRizzo Posted October 7, 2020 Report Share Posted October 7, 2020 They should screw on to the back of the gauge cluster just fine. Not much you can do about the glare....dont bother with the domed glass, it makes it worse... 2 1 Quote Link to comment
Crashtd420 Posted October 7, 2020 Report Share Posted October 7, 2020 That looks awesome... 1 Quote Link to comment
