jalexquijano Posted July 30, 2018 Report Share Posted July 30, 2018 I recently installed a 1761 Pertronix module and 1.5 coil with ballast resistor in my 1972 240z. I also decided to change the 4 year old battery with a Brand new 500 amp battery. After all of these changes i am now noticing that the tach needle is fluttering when the car is sitting on idle. Is this normal? If not, how can it be solved? Quote Link to comment
jalexquijano Posted July 31, 2018 Author Report Share Posted July 31, 2018 The weird thing is that the tach needle only flutters at idle when the car has been warmed and driven. At initial warm up it remains quite steady. Any other remedy? Quote Link to comment
jalexquijano Posted August 3, 2018 Author Report Share Posted August 3, 2018 On 7/30/2018 at 1:09 PM, Jesse C. said: Problem solved. It was the Pertronix Ignitor Module. I had one spare lying around, replaced it and it no longer seems to affect the tach needle. Is this common with Pertronix ignitor? Quote Link to comment
banzai510(hainz) Posted August 3, 2018 Report Share Posted August 3, 2018 (edited) maybe the connection just was better when you installed the other one I run 3 Pertronix on my 3 datsuns. Well 2 now sold one and had no proplems with them besides tape might wear out or magnet ring magnets stuck to the dsit shaft cause tape is worn . But eleltrically have been fine but I dont run a tach so cant help you there. good to ck bushing play every year or so(distributor wiggle) from a wron bushing will cause high RPM cut out. I just plain wear out my distributors or the vac adv goes to hell or springs break. Edited August 3, 2018 by banzai510(hainz) Quote Link to comment
jalexquijano Posted September 26, 2018 Author Report Share Posted September 26, 2018 OK Quote Link to comment
