84 720 KC 4x4, No Start
New battery, new ignition switch, new fuel pump relay, new starter, alternator was tested as good, fuses are all good, head lights work, battery light is on when key is ON  ,  motor would crank over then slowly lose electricity...like a dead batt. Now it just clicks. I tried to jump it and had the same results. The voltometer is reading 12 amps.   Any ideas of where to look Next? Cpuld it be losing power due to a bad ground? Why would it lose voltage when I turn the key to start? Thanks!
  • Replies 0
