Fishinpreacher Posted July 24, 2018 Report Share Posted July 24, 2018 I just purchased a 1984 Nissan 720 pickup with 88300 miles! Garage kept it’s whole life. Interior and exterior look factory new. Engine compartment looks brand new. Has old school camper top. Truck bed has never hauled anything and has rubber mat protection over bed floor. i want to add power steering and maybe AC. Any suggestions? 1 Quote Link to comment
datzenmike Posted July 24, 2018 Report Share Posted July 24, 2018 Both options were available on the 720s. Just find one that already has it and swap it on. Pretty sure the steering column is shorter and needs to be swapped also. 1 Quote Link to comment
Charlie69 Posted July 26, 2018 Report Share Posted July 26, 2018 Find a cheap truck that has AC and power steering and swap the parts. I suggest buying the whole truck as there is a lot to swapping the AC in. I just traded 2 AC setups to Captain 720 only because he came to AZ on business and picked up a Z24 with a complete 5 speeed swap for one of his trucks. The AC wiring is part of the main harness so you will need it also. When I have more time and if you need more info on the AC swap I can provide more information. 1 Quote Link to comment
720_Jeff Posted July 28, 2018 Report Share Posted July 28, 2018 Charlie, when you do have time, please share. I am looking to put A/C into my truck, 85 std cab. Too darn hot here in California to not have A/C 2 Quote Link to comment
720_Jeff Posted July 28, 2018 Report Share Posted July 28, 2018 One more. Another good source for information, is FaceBook Nissan 720 Owners group. Here you will find some documentation on the A/C install: https://www.facebook.com/groups/720Owners/files/ 1 Quote Link to comment
Fishinpreacher Posted August 2, 2018 Author Report Share Posted August 2, 2018 Thanks a ton! I have a new issue. The brake lights won’t go off. Any idea what might be causing this? Quote Link to comment
datzenmike Posted August 2, 2018 Report Share Posted August 2, 2018 The switch is above the pedal and adjustable or replicable. Some have a small pad on the brake pedal that falls off and then when the pedal is raised it doesn't reach and open the switch to turn the lights off. Quote Link to comment
Charlie69 Posted August 2, 2018 Report Share Posted August 2, 2018 (edited) What Mike is talking about is the rubber bumper falls off and does not let the switch turn off. Re adjust the switch. Edited August 2, 2018 by Charlie69 Quote Link to comment
720_Jeff Posted August 2, 2018 Report Share Posted August 2, 2018 People have been known to put a couple of coins together and tape/glue them to the spot, some paper on the spot, and a ton of other things. Proper part number 46512-h0101, can be found all over eBay for around $13, or if a dealer is nearby, I'm sure the price is similar. Here is a link on eBay for one of them, just the first one I found, there are others cheaper if you look. It has the pic https://www.ebay.com/itm/Genuine-Rubber-stopper-46512-H0101/182575627848?epid=1722707910&hash=item2a825afe48%3Ag%3AfjgAAOSwmSdaVOys&_sacat=0&_nkw=182575627848 Quote Link to comment
datzenmike Posted August 3, 2018 Report Share Posted August 3, 2018 Probably one of those sticky felt bumpers for the bottom of kitchen chairs would do. 1 Quote Link to comment
Stoffregen Motorsports Posted August 3, 2018 Report Share Posted August 3, 2018 Are the 720 brake light switches adjustable? I mean, do they have a threaded body like many other models? If so, you could always adjust the switch, as a stop gap measure until the bumper is purchased. Quote Link to comment
720_Jeff Posted August 3, 2018 Report Share Posted August 3, 2018 The 720 brake light switch is adjustable, but the 'plunger' portion of the switch, will go right thru the hole in the brake pedal, where the button goes. So, you'll need a stopper of some kind. Tons of options, all of which are cheaper than getting a fixit ticket for no brake lights. Here in CA, there is a court administrative fee for clearing a fixit ticket. Law Enforcement, will also has a nominal charge for signing off the ticket. In Orange County, court charged $25. I had a buddy sign-off the ticket, but otherwise that would have been another ten bucks at the PD counter. Quote Link to comment
