Abe Froman Posted July 23, 2018 Report Share Posted July 23, 2018 I am looking for a Pitman shaft seal for a 510 steering box, here is the factory part # 48137-16500. I really don't want to remove it to see if a seal manufacturer can match it as it will probably not come out in-tacked. I am told it is NLA, and Rockauto does not have them anymore, anyone have any idea's ? Thanks, Quote Link to comment
datzenmike Posted July 24, 2018 Report Share Posted July 24, 2018 Hi Abe. I just can't see this being NLA. I've found that the B-210 and the 610 also use this number BUT from '74 on the 610 uses #48137-36700. 48137-36700 is also used in the Roadster, 520/521, 620, 710, 810, S10 (200sx) S110 (200sx) and the A10. I'll bet this is the same seal. They're under $5 I'm pretty sure the 510 box uses a bushing rather than a row of needle bearings to support the sector shaft. I lifted a sector shaft out of another Datsun box and was showered with a double row of them. Other boxes have a seal then a washer under it and then a C clip to retain everything you'll have to look on the 510 box. At any rate once the seal is removable I used two long wood screws and screwed them up between the case and the sector shaft into the seal and then pulled it out with pliers. I greased the new one and used a pipe to get it started then put the washer in and tapped it home till I could fit the C clip. Again my info does not show the 510 having either a washer or C clip. Quote Link to comment
Jesse C. Posted July 24, 2018 Report Share Posted July 24, 2018 I found this page with interchange info, check it out https://www.yoyopart.com/oem/11584212/datsun-4813716500.html Quote Link to comment
Abe Froman Posted July 25, 2018 Author Report Share Posted July 25, 2018 5 hours ago, Jesse C. said: I found this page with interchange info, check it out https://www.yoyopart.com/oem/11584212/datsun-4813716500.html Jesse, I ordered a couple online once I had some part numbers and dimensions to use. That page worked great, Thanks ! But it started me thinking that I should maybe get the seal for the steering shaft also. Now all I need in the part number for that to use on that interchange page. Quote Link to comment
Jesse C. Posted July 25, 2018 Report Share Posted July 25, 2018 15 minutes ago, Abe Froman said: Jesse, I ordered a couple online once I had some part numbers and dimensions to use. That page worked great, Thanks ! But it started me thinking that I should maybe get the seal for the steering shaft also. Now all I need in the part number for that to use on that interchange page. Glad you found it useful ? If you find that other part number, post it here so I can get one too! Quote Link to comment
datzenmike Posted July 25, 2018 Report Share Posted July 25, 2018 48029-04100 is a worm gear seal. Fits the rear cover housing with the 3 small bolts. There is also an O ring under the rear cover housing... 48035-71200 Quote Link to comment
Abe Froman Posted July 25, 2018 Author Report Share Posted July 25, 2018 The seal is still available from Nissan, but not the O-ring. Quote Link to comment
