Shane Posted July 22, 2018 Report Share Posted July 22, 2018 So me and my bud r trying to put a 350 small block Chevy into a datson b210 and we r having a problem trying to find a adapter to make the 350 work with the trans that’s in the b210 Quote Link to comment
datzenmike Posted July 22, 2018 Report Share Posted July 22, 2018 The stock 60 series 4 speed will probably get you to the crosswalk on the other side of the intersection before it grenades. Geezus, use a 350 turbo-hydromatic that comes with a 350. Cut the floor out if you have to. All things equal, an automatic will be easier to do, more consistent, more reliable, break fewer parts on the B, and be just plain easier to drive than a standard. You'll have zero problems roasting the tires. 1 Quote Link to comment
Bleach Posted July 22, 2018 Report Share Posted July 22, 2018 I hope you get 50 mpg as well Quote Link to comment
Duncan Posted July 30, 2018 Report Share Posted July 30, 2018 (edited) Probably cheaper and easier to cut the floor pan and plant it on an S10 frame. You'd get bigger brakes, drop in drivetrain install, and easy aftermaket parts availability.. Bag it, channel the body over the frame, and go Hella Flush. Don't forget the rear wing and big Fart Can exhaust.. Edited July 30, 2018 by Duncan 2 Quote Link to comment
Draker Posted July 30, 2018 Report Share Posted July 30, 2018 Murdered out with altezzas Quote Link to comment
metalmonkey47 Posted July 30, 2018 Report Share Posted July 30, 2018 This sounds like it's going to be a hilarious build. Please post pics. Quote Link to comment
