Front Disc brakes LOCKED 1979 620
ethree0
Searched, couldn't find the exact answer i was looking for.
Recently purchased this truck, and everything while "original" was pretty tired. I bled the brakes on all four, and even went ahead and installed a rebuilt master cylinder (3/4") on the truck (everything was spongy after the bleed). Everything seemed fine and I even had the truck on the highway without issue. Drove it fine the day before the issue started up, but now the front calipers seem locked on the front discs.
Drove it about 8 minutes without too much issue (albeit dragging slightly), but on the drive back the fronts began to smoke and rolling is pretty much out of the question.
Any insight on this? I found a different post earlier,
but this doesn't seem to exactly answer my particular question.
thanks in advance.
  • Replies 3
drums on my 521 did something like that..got tighter and tigher after several stops. Problem was I didn't have any extra slack in the brake pedal, so when I took my foot off the brake pedal,  the pushrod in the  MC was just barely unable to fully come back out. not sure if same for you, but the brake pedal has to allow the MC piston to fully back out when you're not on the brakes. Otherwise there will be this continual build up of a tiny amount of pressure in the brakes. Should be just a bit of play when you're not on the brake pedal.
