Site Updated ??​​​​​​​
  • Replies 99
Figured out the Avatar, I guess a circle is your only avatar shape.  I git what I wanted after a couple of oops!  LOL  The Avatar is now named "Profile Photo" and can be found in "Edit Profile".
Still have not figured out the signatures.
31 minutes ago, ]2eDeYe said:
Sig is in the edit profile on the upper right in your pic. Scroll to the bottom, it is the about yourself window. Seems to be a character limit.
Got stuff in the area but doesnt show up on post
23 minutes ago, Icehouse said:
New layout is interesting.
You’re interesting
On the backend it says it’s rebuilding stuff, so maybe the signature is part of that... I’ll see when it’s finished.
Yours will not look like my example because that is a screen shot of my edit profile.
There is red writing and a line to the wording.
Yours probably has a "circle with a G in it."
Edited by Charlie69
37 minutes ago, thisismatt said:
You might just have to start clicking randomly to find it. Maybe pretend like you have Tourette's syndrome
That's funny.....
I'll pass on that one.
Maybe you all will figure this mess out in a week.
This is not correct now that the Update is more complete Thomas' information below is correct. You can access the signature by clicking on the white down arrow in the yop right hand corne of the screen click on "Account Settings", "Signature."
The Signature is now called the "Profile Fields" and is located in "Profile, Edit".  When you get to Profile, Edit you need to scroll down with the scroll bar in the main window.
When you get to the bottom you will find the " Profile Fields" are where you can add links or pictures or text. after adding info you must log off of Rastun and log back on for this to work.
Mine looks like this after adding links to my truck threads.
Edited by Charlie69
Information is incorrest
when you get to the bottom you will find the " Profile Fields" are where you can add links or pictures or text.
I think what you're showing actually appears in the "About Me" section of your profile. That's where I thought the signature was at first too, but it's actually in "Account Settings." See the image below:
