thisismatt 6,617 Report post Posted July 17, 2018 Dual fuel tanks in my work F250. Front pump went out today after struggling the last two weeks. Dealer wants $607...hahaha. Still nearly $400 online, though...laaame Quote Share this post Link to post
I'm BLUE 1,448 Report post Posted July 17, 2018 4 minutes ago, thisismatt said: Dual fuel tanks in my work F250. Front pump went out today after struggling the last two weeks. Dealer wants $607...hahaha. Still nearly $400 online, though...laaame What year/setup ? 1 Quote Share this post Link to post
datzenmike 30,782 Report post Posted July 17, 2018 Buy a $50 in line pump. 1 Quote Share this post Link to post
thisismatt 6,617 Report post Posted July 17, 2018 2 minutes ago, I'm BLUE said: What year/setup ? 97 F250 XLT 7.5L 460 gas...155 wheelbase, CA emissions if that matters (different timing cover with crank trigger). Not sure which is the correct pump yet...I need to go double check the tank size. I think I need the F6TZ-9A407-BB, but some sites say the PFB2 is a substitute...eg rockauto lists the PFB2 as an F6TZ-9A407-BB, while listing the F6TZ-9A407-BB for about $100 more... 1 Quote Share this post Link to post
I'm BLUE 1,448 Report post Posted July 17, 2018 (edited) Eh Edited July 17, 2018 by I'm BLUE 1 Quote Share this post Link to post
thisismatt 6,617 Report post Posted July 17, 2018 11 minutes ago, I'm BLUE said: Eh I thought you were going to help ? 1 Quote Share this post Link to post
bananahamuck 14,374 Report post Posted July 17, 2018 We are only here for moral support ,, if any. 2 1 Quote Share this post Link to post
bananahamuck 14,374 Report post Posted July 17, 2018 Go get-um tiger 2 Quote Share this post Link to post
I'm BLUE 1,448 Report post Posted July 17, 2018 (edited) 17 minutes ago, thisismatt said: I thought you were going to help ? Lol sorry i deleted all i typed.... Brpther and father have 92 and 93 f150 dual tank 5spd 300ci 6cylinder specials. Fathers front tank pump was thlught to have a problem...before i was going to change it...i de ided to just umped a bunch of GOOD injector cleaner down it....i hate pulling tanks.beds....lol....t only had one hiccup since. Ran great since then and still driving today ! Brothers rig has 298k on both original pumps...although one is noisy...lol I ^^^ Sometimes the connectprs get hot from overtime usage , so watch all your pigtails on the fuel pump before reassembly. Both rigs born and raisec i. The PNW... I believe you are correct. If your sender is ok , and you feel confident that you can zip apart your rig....id just buy a fuel pump , connector , and have some good clamps on hand. Ive done fuel pumps as a module unit itself and installing the fuel pump in the module before reinserting. Makes no matter as its your time. I'd clean the sender though... lol Or call a ford dealership to confirm the part #....you might be dead before they do though.....lol I wonder if you have some known issues or defect by design .......TSB's out on your rig ? Edited July 17, 2018 by I'm BLUE 1 Quote Share this post Link to post
thisismatt 6,617 Report post Posted July 17, 2018 5 minutes ago, I'm BLUE said: Lol sorry i deleted all i typed.... Brpther and father have 92 and 93 f150 dual tank 5spd 300ci 6cylinder specials. Fathers front tank pump was thlught to have a problem...before i was going to change it...i de ided to just umped a bunch of GOOD injector cleaner down it....i hate pulling tanks.beds....lol....t only had one hiccup since. Ran great since then and still driving today ! Brothers rig has 298k on both original pumps...although one is noisy...lol ^^^ Sometimes the connectprs get hot , so watch all your pigtails on the fuel pump. Both rigs born and raisec i. The PNW... I believe you are correct. If your sender is ok , and you feel confident that you can zip apart your rig....id just buy a fuel pump , connector , and have some good clamps on hand. Ive done fuel pumps as a module unit itself and installing the fuel pump in the module before reinserting. Makes no matter as its your time. I'd clean the sender though... lol Or call a ford dealership to confirm.....you might be dead before they do though.....lol 22 Truck was running fine and then sat for 10 days while I was out of town. Got back and the next day into work got a CEL for lean condition on right bank, but otherwise seemed to be running fine. Figured dirty maf or vaccuum leak. Cleaned the maf with no change and couldn't find any vacuum leaks. Then started thinking I was having transmission problems as things were acting sluggish getting up to speed on the freeway, but it wasn't until today that I actually noticed a major bog on acceleration (I'm generally pretty nice to the truck and don't accelerate very hard). Put it into 2nd and mashed the gas and it would almost die, and then started almost dying under normal light acceleration. Was going to see about checking the fuel pressure and it wouldn't even stay running...switched to rear tank and everything is fine. Switching to front tank while driving kills it. I imagine changing it is going to be a bastard - it's also a utility bed full to the rafters. 1 Quote Share this post Link to post
Dolomite 2,163 Report post Posted July 17, 2018 On 7/15/2018 at 9:19 PM, tr8er said: Or use one of the many other options God gave. Only one pregnancy hole. 2 Quote Share this post Link to post
KoHeartsGPA 8,905 Report post Posted July 18, 2018 On 7/16/2018 at 8:40 PM, thisismatt said: Dual fuel tanks in my work F250. Front pump went out today after struggling the last two weeks. Dealer wants $607...hahaha. Still nearly $400 online, though...laaame Ford, they circle the problem. 1 Quote Share this post Link to post
paradime 7,558 Report post Posted July 18, 2018 5 hours ago, KoHeartsGPA said: Ford, they circle the problem. I heard Ford has their F250 fuel pumps made by Trappist monks in the Swiss Alps, so... Quote Share this post Link to post
thisismatt 6,617 Report post Posted July 19, 2018 6 hours ago, KoHeartsGPA said: Ford, they circle the problem. Free is free 1 Quote Share this post Link to post
Jesse C. 10,491 Report post Posted July 19, 2018 Well, it is that special time of the year to avoid going down town! 2 1 Quote Share this post Link to post
paradime 7,558 Report post Posted July 19, 2018 3 hours ago, Jesse C. said: Well, it is that special time of the year to avoid going down town! Fattest Batmen I've ever seen. Well even nerds need to get laid once and a while. 1 Quote Share this post Link to post
tr8er 6,113 Report post Posted July 19, 2018 33 minutes ago, paradime said: Fattest Batmen I've ever seen. Well even nerds need to get laid once and a while. Yeah, and they somehow retain some quality women. Quote Share this post Link to post
