Introduction
Hello everyone. New to Ratsun but not Nissan/Datsun. Here are a few projects I'm working on and looking for parts for.
1984 Nissan 720 4X4 King Can
Planning on swapping in a H233 rear axle with a Pathfinder 4.375 LSD and rear disc.
X2 1965 Datsun L320
Blue one I'll be keeping stock.
Red one will probably get a 13b rotary swap.
Now Sold 1964 NL320
Was going to be a long term project but decided it would be better to let it go to someone who was going to finish it.
https://photos.app.goo.gl/qPiPGQnnFfGStDoB9
  • Replies 5
I had an SAS 620 with lots of room. The Toyota axle was slightly wider than the rear and I also was looking at a Pathfinder 4.625 LSD with disc because of the 33" tires. I cut all the coil and 4 link off and got it ready for welding... and then never finished it.
  • 1 month later...
I was lucky and found a D21 axle housing for the Pathfinder disc swap. I'm still searching for a R180 in 4.375 or 4.625 (I found both ratios). So far, I've just been repairing small odds and ends on the truck to make it more drivable.
Once I find a front diff, I'm planning on swapping the rear in to give the truck some grunt back. Eventually, I'll be swapping to a KA24DE out of a frontier with a 240sx intake and harness. Hopefully, that will be much later down the road.
Only the Pathfinder automatic with Z24i engine had the 4.625 R-180 with C-200 4.625 rear differential. There were no KA Pathfinders and the VG uses a monster H233 rear end and R-200 front.
The Hardbody 4x4 had 4.375 R-180 with Z24i engine and C-200 diff.
The KA powered Hardbody 4x4 had 4.11 and 4.375 R-180 and C-200 rear diff.
The VG powered Hardbody used an R-200 front and H-233 rear.
