Farmer Posted June 18, 2019 Author Report Share Posted June 18, 2019 7 hours ago, Draker said: Did you attempt the tube method? I struggled with bleeding my 510 for a while until I did this. You can literally just keep pumping and pumping. No need to close the bleeder valve every time. Set the bleeder so it's tight enough not to leak around the threads, but open enough to still pass fluid. Sometimes it's a difficult balance.. but I've been doing all my cars this way. I did get a vacuum setup but way to much air was getting through the threads. Even the brand new calipers. So it was done the the two person technique. 6 hours ago, Stoffregen Motorsports said: Bleeding brakes is one of those situations where it's nice to have a few tricks up your sleeve. Gravity bleeding, pressure bleeding, two person bleeding, vacuum bleeding. These are all different tools in the tool box. Question - are your drum brakes adjusted properly? If not, you may never get them bled properly. This was on my list to try next( probably should of done this first) Was looking at what the proportional valve actually does. Read on ratsun about how to go about adjusting it, but seemed to be wrong. Why would you want to build pressure for back brakes Instead on front backs. Especially when backs are already locking up before fronts. May have to re read some of this stuff 2 Quote Link to comment
Stoffregen Motorsports Posted June 19, 2019 Report Share Posted June 19, 2019 Rear brakes on trucks are designed to activate first to help keep the truck going straight under hard braking with heavy loads. 2 Quote Link to comment
Farmer Posted August 31, 2019 Author Report Share Posted August 31, 2019 Well that just sucks. Picture hosting site is closing down. Have until Sept 4 to get my pics off. Thats alot of pics from this build and my main one 1 Quote Link to comment
Charlie69 Posted September 3, 2019 Report Share Posted September 3, 2019 Which hosting site? Quote Link to comment
Farmer Posted September 4, 2019 Author Report Share Posted September 4, 2019 22 hours ago, Charlie69 said: Which hosting site? use.com have been using them for like 10+ years signed up with postimg.cc 1 Quote Link to comment
Charlie69 Posted September 4, 2019 Report Share Posted September 4, 2019 (edited) I have been using postimage.cc ever since PhotoBucket held my pictures for ransom. Edited September 4, 2019 by Charlie69 1 Quote Link to comment
Farmer Posted May 3, 2020 Author Report Share Posted May 3, 2020 EI match box Hooked up. using points coil for now. Used wire from another wire harness to keep it stockish looking And it looks like I still need to re link my pictures 3 Quote Link to comment
wayno Posted May 3, 2020 Report Share Posted May 3, 2020 I can see your photos. You really should use an EI coil, they are everywhere, I believe any 1978+ Datsun/Nissan coil will work. 2 Quote Link to comment
banzai510(hainz) Posted May 3, 2020 Report Share Posted May 3, 2020 Using the stock coil and ballast is more like a Pertronix conversion wire set up. yes one go EI coil and bypass the resistor if one chooses so Quote Link to comment
Farmer Posted May 3, 2020 Author Report Share Posted May 3, 2020 5 hours ago, wayno said: I can see your photos. You really should use an EI coil, they are everywhere, I believe any 1978+ Datsun/Nissan coil will work. Im missing all my photos and the first few pages. The ones you can see are posted by other forum members 1 Quote Link to comment
wayno Posted May 4, 2020 Report Share Posted May 4, 2020 I see all the photos you posted from June 10, 2019 to now, before June 10 they are gone. 2 Quote Link to comment
Farmer Posted May 20, 2020 Author Report Share Posted May 20, 2020 (edited) EI coil came in. Now to install Edited May 20, 2020 by Farmer 3 Quote Link to comment
Farmer Posted May 20, 2020 Author Report Share Posted May 20, 2020 (edited) Installed new weber and had to customize the cable bracket Edited May 20, 2020 by Farmer 4 Quote Link to comment
Pacific coast Datsun Posted May 20, 2020 Report Share Posted May 20, 2020 4 hours ago, Farmer said: Installed new weber and had to customize the cable bracket Looks good. I also had to fab a throttle cable bracket on my 74. 2 Quote Link to comment
Farmer Posted May 21, 2020 Author Report Share Posted May 21, 2020 EI coil wired 4 Quote Link to comment
Farmer Posted June 7, 2020 Author Report Share Posted June 7, 2020 Recent pics over the weekend 6 1 Quote Link to comment
gene knight Posted June 8, 2020 Report Share Posted June 8, 2020 Farmer: dang that thing looks good, i wish i had bought it when it was for sale but i didn't know of all the work that it needed when you bought it, i am glad that it went to you 1 Quote Link to comment
AlexDeLarge Posted June 8, 2020 Report Share Posted June 8, 2020 Awesome truck man!! Still say it needs early stock grill with beauty rings...👍 1 Quote Link to comment
Draker Posted June 8, 2020 Report Share Posted June 8, 2020 Post the video!!! 😉 1 Quote Link to comment
Farmer Posted July 4, 2020 Author Report Share Posted July 4, 2020 Found a place to take some photos 3 Quote Link to comment
