Mattndew76 Posted December 30, 2021 Author Report Share Posted December 30, 2021 Pappy sits low. 1 Quote Link to comment
datzenmike Posted December 30, 2021 Report Share Posted December 30, 2021 13 hours ago, Mattndew76 said: Managed to drive the pappy home and blow a fuse. Is this another euphemism? Quote Link to comment
Mattndew76 Posted December 30, 2021 Author Report Share Posted December 30, 2021 (edited) nope. Truck popped a fan fuse, and I ordered a new ignition cylinder. The tractor style one that was in this thing has to go. Edited December 31, 2021 by Mattndew76 Quote Link to comment
Mattndew76 Posted December 31, 2021 Author Report Share Posted December 31, 2021 I might have to install a manual OD cable kit to get this C6 to shift into OD. I can ratchet shit 1st to 2nd but once I ratchet into D it bounces back to 1st. Low on ATF maybe? or Air in the AT hydro system. Quote Link to comment
Mattndew76 Posted January 1 Author Report Share Posted January 1 Found my issue with the lack of shifting in the D position. I smacked the dual diaphragm module when installing the engine and trans. it’s bent. Quote Link to comment
Mattndew76 Posted January 2 Author Report Share Posted January 2 Out with the busted old and in with the adjustable new. 1 Quote Link to comment
Mattndew76 Posted January 2 Author Report Share Posted January 2 Busy night tonight. 2 Quote Link to comment
Mattndew76 Posted January 6 Author Report Share Posted January 6 Put 60 miles on the pappy today. Noticed a bit of vibration in the front passenger area. I am pretty sure I have a dead strut. Maybe getting some wheel hop at 35mph as a result. 2 Quote Link to comment
Mattndew76 Posted January 6 Author Report Share Posted January 6 Anyone love tunable velocity stacks like I do? 2 Quote Link to comment
Mattndew76 Posted January 10 Author Report Share Posted January 10 Finished these fellers. now its Time to make gate latches. 2 Quote Link to comment
Mattndew76 Posted January 24 Author Report Share Posted January 24 Got a gift from my Father. Rest of the system will be arriving soon. 4 Quote Link to comment
Mattndew76 Posted March 3 Author Report Share Posted March 3 I'm cutting up one of these to stuff parts of it into a 1200 coupe.... Video's coming soon. 4 Quote Link to comment
Lockleaf Posted April 12 Report Share Posted April 12 Well that appears to be significantly nicer than any of my toys. Well made good sir. 1 Quote Link to comment
Mattndew76 Posted April 12 Author Report Share Posted April 12 Tis but a geometric object holding hydraulic oil. You're doing an amazingly cool pan swap. Quote Link to comment
Lockleaf Posted April 13 Report Share Posted April 13 Well thank you but you will note high levels of precision arent my specialty. I admire those who can work in thousandths or better. Quote Link to comment
datsunfreak Posted April 13 Report Share Posted April 13 2 hours ago, Lockleaf said: you will note high levels of precision arent my specialty Sometimes good enough is good enough. 😉 3 Quote Link to comment
Mattndew76 Posted May 5 Author Report Share Posted May 5 https://rumble.com/v13kw5i-replicating-and-cnc-milling-a-corroded-valve-block..html 2 Quote Link to comment
