620owner Posted May 24, 2018 Report Share Posted May 24, 2018 Getting ready to fill up the 5-speed 71B What's the best oil to use ? Some say ONLY: GL-4 Yellow Metal Safe Some say it doesn't really matter. Some say go synthetic. There are a ton of new oils out there now, viscosity varies a lot. Hoping someone has experimented and can save me guessing. Quote Link to comment
Dolomite Posted May 24, 2018 Report Share Posted May 24, 2018 It does matter. GL-4 only, synthetic is ok to run as long as it’s GL-4. I run Lucas oil synthetic, others use redline or royal purple...all three are quality gear oils. My zx 5 speed shifts better on synthetic. 2 Quote Link to comment
flatcat19 Posted May 24, 2018 Report Share Posted May 24, 2018 Non yellow-safe fluid will eat the brass inside your transmission. Yes, it matters. Being in Ohio, it's not like you can easily find another transmission after you throw a few quarts of that magic voodoo Redline in there. Quote Link to comment
datzenmike Posted May 24, 2018 Report Share Posted May 24, 2018 If going with a synthetic replace the $5 rear seal, only takes a few minutes, and you should do this anyway. I'm using the GM Delco Friction Modified Synchromesh Transmission Oil. You can find it at Lordco a little cheaper than the dealer. It's about 3 times more than regular 80w90 GL4. You need 2 liters for the 71B. I have it in my ZX 5 speed and it allows better shifting when cold, smoother faster shifts and I can now down shift without any grinding. I'm simply amazed with this stuff. Had it for about 5 years now. Best $36 CDN I've spent. 1 Quote Link to comment
620owner Posted May 24, 2018 Author Report Share Posted May 24, 2018 OK from what I'm seeing the new synthetics are now non-corrosive to yellow metal. Most GL5's are saying that the newer additives now make it safe to use. I did find this video which this trany expert explains this very well. He repairs a munci first so go to 11:30 in the video to where he starts the testing of GL4 and GL5's. https://video.search.yahoo.com/yhs/search;_ylt=AwrC5rK1ygZbsgsAjmo0nIlQ;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=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--?gprid=nxPKcVuLSRCz2xr28RAR_A&pvid=cq_y2TEwLjFAxMCYWvBZopnlMjA2LgAAAABikVZM&p=GL4+vs+GL5++oil+tests&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yhs-pty-pty_email&hsimp=yhs-pty_email&hspart=pty&type=admk#id=1&vid=861d4400b4b21f93c3c967db7ee2e11a&action=view He likes the DRIVEN GO RACING 80-90 Quote Link to comment
datzenmike Posted May 24, 2018 Report Share Posted May 24, 2018 GL-5 is for differentials. I'll look at the vid when I get home. There's lots of mis information out there. Quote Link to comment
620owner Posted May 24, 2018 Author Report Share Posted May 24, 2018 Thanks MIke, Good to know, I see the synchromesh fluids and was leery of them because they appeared to be thin like ATF fluid, something I thought would not work well in a gear box. I changed the front seal but I'm going to pull it because it's a single lipped seal. After putting it in I had wished I hadn't. Do you think I should pull the front cover and replace the front seal too ? Did you flush your tranny before changing over to the synthetic ? Quote Link to comment
racerx Posted May 24, 2018 Report Share Posted May 24, 2018 If have a manual go by that. 1 Quote Link to comment
620owner Posted May 24, 2018 Author Report Share Posted May 24, 2018 Here's what the American Petroleum Institute says, what the heck do they know.. API (American Petroleum Institute Classification) GL-4 (Gear Lubricant-4) contains about half the additives of GL-5. Higher concentration of Extreme Pressure additives in GL-5 gear oils may cause the softer metals, such as copper, brass and bronze – which make up the shift synchronizers of a manual transmissions - to suffer premature wear / failure. So, stick with the specified GL-4 classification, in any of your favorite synthetic brands. Mike your fluid, GM Delco Friction Modified Synchromesh Transmission Oil Synchromesh Transmission Fluid, Friction Modified is a synthetic blend manual transmission fluid designed specifically for use in GM manual transmissions. This fluid has excellent lubrication properties that prevent breakdown over time and reduce friction to minimize transmission wear. All-climate fluid that manages temperatures as low as -40 degrees Fahrenheit (-40 degrees Celsius) to as high as 300 degrees Fahrenheit (149 degrees Celsius) Quote Link to comment
datzenmike Posted May 25, 2018 Report Share Posted May 25, 2018 It's sure is thinner, noticeably so. I wondered about this also but as long as it's slippery enough it will work. I noticed right away the transmission made a reassuring click click when shifting between gears. Without any added effort the shift was also quicker. Usually the first few up shifts, mostly into second were 'stiff' till the trans had a few blocks distance on it to 'warm up', more so when near freezing but that all went away. I stopped down shifting into second until at the lowest speed when turning a corner or it would need a very firm PULL to synchronize into gear and often the gears would still grumble a little. This also went completely away. It's been almost 5 years and I'm still waiting for a downside to this stuff. Otherwise it's the best $35 I ever spent on the car. I just drained the GL4 out, the drain is at the bottom so a few hours while doing something else and there wouldn't be more than a 1/4 cup left wetting the inside. I've rinsed a transmission out with ATF before by rolling it around on the lawn, then draining it. I doubt it was necessary. 1 Quote Link to comment
620owner Posted May 29, 2018 Author Report Share Posted May 29, 2018 I'm going to try this synthetic oil. Hope it work's as good as your GM Delco Friction Modified Synchromesh Transmission Oil. Royal Purple 01300 Max Gear Ultra-Tough High Performance Synthetic Gear Oil 75W-90 Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe. Specially designed to extend gear and bearing life, Max Gear provides superior corrosion protection over competing conventional and synthetic gear oils. Royal Purple engineered this ultra-tough, high performance automotive hypoid gear oil to provide maximum protection to heavily loaded gears while maximizing power throughout the drive train. Max Gear outperforms ordinary gear oils by combining the highest quality synthetic oils with Royal Purple’s proprietary Synerlec® additive technology. Quote Link to comment
Crashtd420 Posted May 29, 2018 Report Share Posted May 29, 2018 I'm going to try this synthetic oil. Hope it work's as good as your GM Delco Friction Modified Synchromesh Transmission Oil. Royal Purple 01300 Max Gear Ultra-Tough High Performance Synthetic Gear Oil 75W-90 Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe. Specially designed to extend gear and bearing life, Max Gear provides superior corrosion protection over competing conventional and synthetic gear oils. Royal Purple engineered this ultra-tough, high performance automotive hypoid gear oil to provide maximum protection to heavily loaded gears while maximizing power throughout the drive train. Max Gear outperforms ordinary gear oils by combining the highest quality synthetic oils with Royal Purple’s proprietary Synerlec® additive technology. That's what I am using in my 521 4spd.... i actually have royal purple in everything on my datsun..... 1 Quote Link to comment
datzenmike Posted May 29, 2018 Report Share Posted May 29, 2018 I suspect there is only one maker for this stuff and all they do is add different coloring and containers. I hope it is the same as it works wonders compared to the regular GL-4 1 Quote Link to comment
mainer311 Posted June 12, 2018 Report Share Posted June 12, 2018 I run Nissan genuine GL-4 manual transmission fluid. Figured they would know what works best. 1 Quote Link to comment
240zness Posted June 12, 2018 Report Share Posted June 12, 2018 Great thread.. But the tranny thing is what court my eye Quote Link to comment
620owner Posted June 12, 2018 Author Report Share Posted June 12, 2018 OK, thought I'd let everyone know the results running the "Royal Purple 01300 Max Gear Ultra-Tough High Performance Synthetic Gear Oil 75W-90" in my 5- speed tranny. It's only been a week but the tranny shifts (Up and Down) smooth as butter, it's quiet. I really thought I'd hear a little bearing wine with the synthetic but not so. So far so good, I haven't really hammered it while breaking in a new clutch. I guess I can turn the radio up now, been nervously listening to the tranny. Gonna leave it in and see what happens. Quote Link to comment
datzenmike Posted June 12, 2018 Report Share Posted June 12, 2018 Check every week for wetness at the rear of the transmission, That shit is slippery!! and well squeeze out past an old seal. 1 Quote Link to comment
Arkos Posted November 29, 2021 Report Share Posted November 29, 2021 Hello Everyone, I have been reading this forum for a bit now. I just want to say how awesome and informative and friendly everyone is. Seriously thank you! Has helped me a significant amount. 🖖 Quote Link to comment
toygarzop Posted April 7, 2022 Report Share Posted April 7, 2022 I see the synchromesh fluids and was leery of them because they appeared to be thin like ATF fluid techzpod mobdro download Quote Link to comment
datzenmike Posted April 7, 2022 Report Share Posted April 7, 2022 It's thin. Gear oil and engine oil viscosity are measured differently. The Delco oil I use is thinner than 10w30 in my opinion. Hard to say really but much thinner. Allows a faster synchro engagement but still lubricates and protects. This is most specially noticeable in cold weather or the first few miles when still cold. The 80w90 thickens when cold and even in the summer the first few shifts are stiffer than then warmed up. Secondly is downshifting. Not huge RPM differences but just coming up to stop and you're in the wrong gear and the light changes. Much easier to stuff into first without complaint or rev matching. 1 Quote Link to comment
Montzzz Posted November 21, 2024 Report Share Posted November 21, 2024 I want to change my transmission fluid and differentialso here I am reading this forum Quote Link to comment
Montzzz Posted November 21, 2024 Report Share Posted November 21, 2024 On 5/24/2018 at 7:53 AM, datzenmike said: If going with a synthetic replace the $5 rear seal, only takes a few minutes, and you should do this anyway. I'm using the GM Delco Friction Modified Synchromesh Transmission Oil. You can find it at Lordco a little cheaper than the dealer. It's about 3 times more than regular 80w90 GL4. You need 2 liters for the 71B. I have it in my ZX 5 speed and it allows better shifting when cold, smoother faster shifts and I can now down shift without any grinding. I'm simply amazed with this stuff. Had it for about 5 years now. Best $36 CDN I've spent. HI, reading all the comments here and wondering What you use for the differential? and what you mean by "rear seal"? Thanx in advance Quote Link to comment
datzenmike Posted November 21, 2024 Report Share Posted November 21, 2024 The factory calls for GL-4 80 or 90w gear oil or equivalent. Must be 'yellow metal' or copper alloy safe to use. For the differential GL-5 80-90w gear oil which has, and needs, a higher concentration of anti scuff additives which make it unsuitable for use in the transmission. You can opt for some synthetic blend but in my experience, transmission, transfer case and a differential, it began to seep out of old seals because it's so thin and slippery. Maybe you'll have better luck. 1 Quote Link to comment
Stinky Posted November 24, 2024 Report Share Posted November 24, 2024 I was running Syncromesh. It did shift easily. I ran it for about a year. My trans was noisy....say when you are running 45 in 4th and you let off the gas...it would clatter. It would clatter at other times too. Right now, I have Lucas GL5 in it now. I ordered it off rockauto. The description and picture showed that it was GL4 compatable. The bottle that I got did not....that was the only difference in the bottle that I noted from the picture on RA. I looked it up, the bottle I got did not have that rating on it. I looked at the Lucas website, and they no longer rate it for GL4. I didn't notice this until I was putting the 3rd bottle in. I ordered 3 new bottles that night. I am trying something synthetic. I am on my 2nd day of the above oil. I am not sure if it clatters any less. It is definitely harder to downshift when cold Quote Link to comment
